Home > My Range Rover > TDV8 4.4 - The Joy of Ownership |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 281 |
I need to start reassembling the old girl following Dinitrol treatment at South West Rust Proofing, but first:
26th Jul 2022 3:11pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8338 |
Think on the positive side, at least it won't go rusty....
26th Jul 2022 3:57pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3785 |
Pete, I paid £400 +vat eight years ago, which I thought was a bit expensive, but as a long term investment for a car I always intend to keep , worth every penny.
26th Jul 2022 7:47pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 |
Nice.
26th Jul 2022 8:21pm |
Cheers Mike, yes I agree with the 405 needing it... Pete
26th Jul 2022 8:39pm |
I think my pad squeal was due to an inverse orientation of the anti vibration spring…. Not tested yet but when I went to refit the pad springs, following the orientation that they were when I took them off, I noticed they fouled the wear sensor ( which was probably why it was broken ). With them inverted they clear the wear sensor and I notice that the spring “shoulders” support the top of the pads.
26th Jul 2022 8:53pm |
A brief record of jobs done since acquiring her in April 2022 & future jobs to do ;
31st Aug 2022 10:09pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
Good tip on the orientation of the spring. Mine squeal, and need new pins due to some previous gorilla battering the end into a mushroom
1st Sep 2022 7:01am |
btiratsoo Member Since: 12 May 2020 Location: Hampshire Posts: 174 |
A comprehensive list of jobs! How did you get on with the mega flush in Lancing? Current vehicles:
1st Sep 2022 9:40am |
R&G did a great job, the gearbox is noticeably smoother.
1st Sep 2022 7:53pm |
Thanks! I checked them out and you’re right they look high end. TDV8 4.4 2012 |
1st Sep 2022 7:55pm |
A few cosmetic up grades :
20th Sep 2022 7:45pm |
So, my grand master plan to refurb the brake system went awry on Sunday; having had an advisory for ( minor ) brake pipe corrosion on the MOT in Feb I’ve been acquiring parts for a complete refurb of the brakes including refurb of the front 6 pots, replacement of the rears with OEM spec ones, new flex lines and discs all around and finally, replacement of the fixed lines with kunifer…… all of which costs a small fortune!
13th Aug 2024 10:14pm |
