![]() | Home > Technical (L322) > Forward Alert |
As with most implementations of it, it can suffer from false positives - reflections from buildings, other vehicle glass, low sun etc. etc. it's not a perfected technology but can help and / or hinder. The alternative is to drive defensively. |
Chuckster007 Member Since: 21 Jul 2022 Location: Manchester Posts: 5 ![]() ![]() ![]() |
mine is turned on and it automatically brakes / slows down while on cruise control if it gets too close to a vehicle infront, it distances itself which is a good thing, only negative thing is that it slows down a lot which could end up getting smacked by another vehicle behind you if they tail gate too close. 2010 3.6 Black Vogue SE |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3821 ![]() ![]() ![]() |
Mine is on permanently and never been a problem.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
Forward alert is separate to cruise control, at least in the area that is covered by the tick in the dash menu. The same radar is used for active cruise, as above, but that’s different to Forward alert.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
The cruise control will brake regardless of whether Forward Alert is switched on or not.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
As above, mine is switched on permanently and has alerted me to a few close calls over the years where folks in front have decided to hit the anchors etc. The adjustment using cruise control distance is very useful to alter the distance sensitivity.
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
The ones fitted to DAF HGV's are an absolute pain - they brake hard when cyclists cut across you/pedestrians run across you & there is no reason to react - then, the vehicle telematics flag "heavy braking" & you have to explain yourself to a desk driving transport manager.
The auto braking systems on Tesla's are a danger IME as they can brake when passing / overtaking vehicles on the motorway. I always give them more than the usual safe distance If I'm behind one. 2012 TDV8 Vogue (L322) |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1300 ![]() ![]() ![]() |
I agree with Dr Rob. Saved me a few times as well. Why wouldn't you have it turned on? It's a safety feature. |
misfire84 Member Since: 25 Nov 2020 Location: brecon becons Posts: 37 ![]() ![]() ![]() |
ditto it has saved me one or twice when I have not been concentrating as much as I should of been |
Maybe it is, but please consider the implications as I posted above. If you have an insurance "black box" fitted it could make you seem like you are not a particularly good driver. |
I agree with what you said Sam but I rarely use the cruise control and just have the warning sounds which I've found useful in the past. |
That's incorrect. Forward Alert does not brake the car (it's an alert) and insurance black boxes do not monitor driver aids. 2015 Range Rover Autobiography 4.4 SDV8 |
