Home > Maintenance & Mods (L405) > Failure driver seat massage and function |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35372 |
there was a deflation device on the L322 so kinda thinking yours should have the same....
10th Jul 2022 9:11am |
had a quick look and couldnt find any ref to a 'valve' release or such in the WM..
10th Jul 2022 9:28am |
vanquishspirit Member Since: 10 Feb 2012 Location: United Kingdom Posts: 131 |
Thanks for the check out. I shall have to call the dealership tomorrow. Got to drive to Edinburgh and back on Tuesday which will be a pain with this poking in my back ! 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
10th Jul 2022 11:00am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
As Stan says, a battery reset would be the way to go... Might be easier for you to simply unplug the seat and leave it ten mins, then plug it in and see if it comes back to life... |
10th Jul 2022 2:35pm |
Ok thanks for that. I shall a disconnection if I can see the plug 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
11th Jul 2022 8:43am |
PCMM Member Since: 26 Nov 2015 Location: East London Posts: 3 |
I have this issue in a 4 year old SVA, but LR main dealer has confirmed it needs a new unit, but that LR have the part on back order.
22nd Jul 2022 8:38pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
If LR have it on backorder from the OEM, then it will be on backorder to everyone else too. As it is part of an assembly (i.e. the seat) then they won't be able to do a 'line pinch', assuming it's still a current production item. The next level down is a 'pack pinch', generally only for VOR cases and still dependent upon OEM supply, given the ongoing problems with Silicon supply, it may be time to get creative and ask your dealer to try and manually deflate the seat. |
22nd Jul 2022 9:02pm |
That's good to know, thanks Phoenix 👍🏻 |
23rd Jul 2022 8:13am |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 467 |
Hi. My massage function went wrong 18months ago. It was ordered then. The part arrived last week. It will be fitted next week SDV8 AB MY 2020
23rd Jul 2022 12:32pm |
I did lots of searching for the part about a year ago I think. There were a few in the US. But I found none in Europe.
23rd Jul 2022 12:42pm |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 236 |
I get many parts from EBay from crashed vehicles. Most come from Lithuania. Do a part number search. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
23rd Jul 2022 4:39pm |
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 |
Can you switch passenger side components over to driver side? Might be a workaround while waiting for new parts. Unless it’s all integrated in which case that defo won’t work! L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
23rd Jul 2022 9:49pm |
Matthias Member Since: 30 Jul 2022 Location: Brugge Posts: 3 |
Hi, i have the same problem. Why do these things always happen when you are on holiday? 😅
29th Jul 2023 2:43pm |
Jimbo255 Member Since: 14 Aug 2022 Location: Surrey Posts: 1 |
I also have the same issue with the part on back order (6 months now). The dealer did deflate mine. I have asked them for the part number but they haven't been forthcoming with it. Does anyone here know what it is for the solenoid?
8th Aug 2023 9:14am |
