Home > Maintenance & Mods (L405) > Failure driver seat massage and function
vanquishspirit
My three year old L405 autobiography has developed a faulty driver seat massage and bolster adjustment function. Annoyingly it has stalled with the two upper air bag fully protruding into my back and I cannot get them down ! Any ideas chaps ? 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
1972 Suffix A fully restored 2 door
1970, chassis number 26 the first of the press launch cars, Masai Red
2013 4.4SDV8 Autobiograpahy
Post #636549 10th Jul 2022 9:03am
there was a deflation device on the L322 so kinda thinking yours should have the same....
a perusal of the WM might be in order. ... - .- -.
Post #636550 10th Jul 2022 9:11am
had a quick look and couldnt find any ref to a 'valve' release or such in the WM..
i'd try a battery reset , might work.. ... - .- -.
Post #636557 10th Jul 2022 9:28am
vanquishspirit
Thanks for the check out. I shall have to call the dealership tomorrow. Got to drive to Edinburgh and back on Tuesday which will be a pain with this poking in my back ! 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
Post #636564 10th Jul 2022 11:00am
As Stan says, a battery reset would be the way to go... Might be easier for you to simply unplug the seat and leave it ten mins, then plug it in and see if it comes back to life... Thumbs Up
Post #636580 10th Jul 2022 2:35pm
vanquishspirit
Ok thanks for that. I shall a disconnection if I can see the plug 2006 S/C owned from new. Black, sand with black inserts. Shes a thirsty girl. ( now gone)
Post #636637 11th Jul 2022 8:43am
PCMM
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I have this issue in a 4 year old SVA, but LR main dealer has confirmed it needs a new unit, but that LR have the part on back order.
Can anyone recommend decent parts suppliers in the UK that I can contact?
Thanks in advance.
2018 5.0SC SVA
2006 4.2S (sadly missed)
Post #637603 22nd Jul 2022 8:38pm
Phoenix
If LR have it on backorder from the OEM, then it will be on backorder to everyone else too. As it is part of an assembly (i.e. the seat) then they won't be able to do a 'line pinch', assuming it's still a current production item. The next level down is a 'pack pinch', generally only for VOR cases and still dependent upon OEM supply, given the ongoing problems with Silicon supply, it may be time to get creative and ask your dealer to try and manually deflate the seat.
Post #637605 22nd Jul 2022 9:02pm
PCMM
That's good to know, thanks Phoenix 👍🏻
Post #637618 23rd Jul 2022 8:13am
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Hi. My massage function went wrong 18months ago. It was ordered then. The part arrived last week. It will be fitted next week SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #637635 23rd Jul 2022 12:32pm
luxmoggy
I did lots of searching for the part about a year ago I think. There were a few in the US. But I found none in Europe.
I hope you don't need to wait as long as I did. SDV8 AB MY 2020
Post #637637 23rd Jul 2022 12:42pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I get many parts from EBay from crashed vehicles. Most come from Lithuania. Do a part number search. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #637649 23rd Jul 2022 4:39pm
ilard
Can you switch passenger side components over to driver side? Might be a workaround while waiting for new parts. Unless it’s all integrated in which case that defo won’t work! L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #637683 23rd Jul 2022 9:49pm
Matthias
Belgium 2019 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Hi, i have the same problem. Why do these things always happen when you are on holiday? 😅
I’m driving a 2021 SVAutobiography Dynamic with the rear seat entertainment Tv’s if that makes a difference.
What seat connector do i have to unplug? And did this help or was it the battery reset that did the trick?
Thx in advance for you answers.
I’m really hopeless at this point cause my dealer doesn’t have time to identify the problem until mid September. Really annoying cause i’m driving at least a 1000km a week. Gonna need a new kidney if i’m not able to deflate the air cells.
Post #670055 29th Jul 2023 2:43pm
Jimbo255
United Kingdom 2018 Range Rover Autobiography SDV8 Balmoral Blue
I also have the same issue with the part on back order (6 months now). The dealer did deflate mine. I have asked them for the part number but they haven't been forthcoming with it. Does anyone here know what it is for the solenoid?
Thanks
Post #670708 8th Aug 2023 9:14am
