Home > Maintenance & Mods (L322) > any protection for air bags |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Unsure if anyone has ever added a lubricant to these & nothing supplied by JLR as far as I'm aware. The only problem that I can see, is what ever you add will this not attract dirt / debris & cause more wear?.
21st Jul 2022 10:55am |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
high i take in what you have said . jlr are not going to state anything as they would like you to buy new at £400 when a pin hole lets go . i was more thinking the chemicals when used on interior that becomes very slippery more like a spray . i wash mine every week so would not get to much mud and grit any way . i use a rubber dressing by wurth for around the door trim rubbers and boot area much like you clean your horse tak and keep is soft stop it from cracking new vehicle purchase
21st Jul 2022 12:50pm |
You could possibly try a silicone spray, that may work. |
21st Jul 2022 1:03pm |
that is more like what i was thinking of more silicon than any thick solid same as you stated not to attract grit etc this could be worth a try .
21st Jul 2022 1:27pm |
Nothing to loose |
21st Jul 2022 2:09pm |
