Home > Maintenance & Mods (L322) > any protection for air bags
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
just thought i would ask does anyone use any sort of chemical spray in and on the air bags . when i clean or wash the beast i power wash on off road height give them a good blast over to get any dust or gritt out . does anyone use a silicone or rubber preserve on and around the bags . much like drive shaft boots to keep them from cracking ? thanks oggy
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #637482 21st Jul 2022 10:39am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Unsure if anyone has ever added a lubricant to these & nothing supplied by JLR as far as I'm aware. The only problem that I can see, is what ever you add will this not attract dirt / debris & cause more wear?.
I agree with your thoughts on cleaning regularly though Thumbs Up
Post #637485 21st Jul 2022 10:55am
oggy
high i take in what you have said . jlr are not going to state anything as they would like you to buy new at £400 when a pin hole lets go . i was more thinking the chemicals when used on interior that becomes very slippery more like a spray . i wash mine every week so would not get to much mud and grit any way . i use a rubber dressing by wurth for around the door trim rubbers and boot area much like you clean your horse tak and keep is soft stop it from cracking new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #637499 21st Jul 2022 12:50pm
Highroller
You could possibly try a silicone spray, that may work.
Post #637500 21st Jul 2022 1:03pm
oggy
that is more like what i was thinking of more silicon than any thick solid same as you stated not to attract grit etc this could be worth a try .
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #637502 21st Jul 2022 1:27pm
Highroller
Nothing to loose Thumbs Up
Post #637505 21st Jul 2022 2:09pm
