Home > Maintenance & Mods (L405) > Dynamic Response reservoir
wealy
Does anyone know if your dynamic fluid runs low a light tells you on the dash.
Post #637216 18th Jul 2022 3:59pm
Mikey
The first you will know is when the red warning light comes on the dash, and logs a System Pressure fault
There is no level sensor/warning
Post #637235 18th Jul 2022 5:51pm
mpirie
As Mikey says, the red warning will come on the dash display advising to stop engine and to get the problem checked asap.
If you plan to top it up, then you need Land Rover cold climate power steering fluid at about £21 per litre on the auction site.
Mike
Post #637243 18th Jul 2022 7:48pm
