Home > Technical (L322) > Fuel Rail/System pressure too high: fault code P0088-17 (6C)
grayst01
Scotland 2012 Range Rover Vogue 4.4 V8 Java Black
Hi All
Can anyone shed any light on this restricted performance fault? I’ve had it appear a couple of times recently which I can ‘clear’ using the GAP IID tool but I’d like to understand the fault now as its happened a couple times… it always seems to be on start-up but not a cold start, after a period of running.
Full fault reads as:
P0088-17 (6C) Fuel rail/system pressure - too high - General electrical failure - circuit voltage above threshold.
Any help/advice appreciated Thumbs Up Cheers, Steven.
2012 Vogue 4.4 TDV8.
Post #636690 11th Jul 2022 9:03pm
GraemeS
Refer to LTB01083 regarding replacing a section of wiring harness to the sensor with the repair kit 108438 plus 3 crimp joiners.
Post #636694 12th Jul 2022 4:16am
grayst01
Thanks Graeme, I’ve managed to get a PDF copy of the bulletin.
Can anyone help with what I do to order/buy the kit to complete this repair?? Cheers, Steven.
Post #636741 12th Jul 2022 5:05pm
GraemeS
The parts should be available from a LR dealer noting that the crimp sleeves requires a tool.
Post #636771 12th Jul 2022 8:51pm
andygts
I believe this is the bosch part number for the plug (1928403966) stick it in ebay etc and you can buy it bare or with tails etc.
I'd always solder rather than crimp
LR108438 harness repair = £30 ish
save £20+ and put it towards some fuel Very Happy
It's on my to do list, happened a few times in last 6 months....also had the stalling at junctions as mentioned in the tech bulletin Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #636811 13th Jul 2022 11:49am
GraemeS
If soldering then the join has to be supported past the spots to where the solder has migrated along the wires to prevent flexing at the ends of the solder which would otherwise break from movement.
PS Thanks for the connector part number.
Post #636813 13th Jul 2022 11:58am
woodyrvf750
Re: Fuel Rail/System pressure too high: fault code P0088-17
grayst01 wrote:
Hi All
@grayst01 - did you get this resolved? If so what was the fix?
I have the same error, also on start up. I can clear it with GAP tool and the car drives fine.
I've spliced in the new fuel pressure sensor wiring harness using heat shrink solder connections.
Post #680821 20th Dec 2023 12:25pm
grayst01
@woody
I actually haven’t done anything with it. It didn’t occur again after those first few times - I did look out the part as per the eBay item and saved it for future reference but hasn’t been an issue again since. Sorry… Shocked Cheers, Steven.
Post #680825 20th Dec 2023 1:58pm
woodyrvf750
Lucky you! Thanks for your reply though. I think I caused the issue when I broke the fuel pressure sensor when I replaced the oil cooler and thermostat housing. I have since bought two genuine bosch fuel pressure sensors in the hope that the first replacement was faulty. Car is booked in with Venture 4x4 for diagnosis Jan 5th 24!
Post #680846 20th Dec 2023 6:02pm
