![]() | Home > Technical (L322) > Fuel Rail/System pressure too high: fault code P0088-17 (6C) |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2567 ![]() ![]() ![]() |
Refer to LTB01083 regarding replacing a section of wiring harness to the sensor with the repair kit 108438 plus 3 crimp joiners. |
grayst01 Member Since: 08 May 2022 Location: Glasgow Posts: 104 ![]() ![]() ![]() |
Thanks Graeme, I’ve managed to get a PDF copy of the bulletin.
The parts should be available from a LR dealer noting that the crimp sleeves requires a tool. |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 360 ![]() ![]() |
I believe this is the bosch part number for the plug (1928403966) stick it in ebay etc and you can buy it bare or with tails etc.
If soldering then the join has to be supported past the spots to where the solder has migrated along the wires to prevent flexing at the ends of the solder which would otherwise break from movement.
woodyrvf750 Member Since: 10 Jul 2023 Location: Stratford Upon Avon Posts: 19 ![]() ![]() |
@grayst01 - did you get this resolved? If so what was the fix? I have the same error, also on start up. I can clear it with GAP tool and the car drives fine. I've spliced in the new fuel pressure sensor wiring harness using heat shrink solder connections. |
@woody
Lucky you! Thanks for your reply though. I think I caused the issue when I broke the fuel pressure sensor when I replaced the oil cooler and thermostat housing. I have since bought two genuine bosch fuel pressure sensors in the hope that the first replacement was faulty. Car is booked in with Venture 4x4 for diagnosis Jan 5th 24! |
