Home > In Car Electronics (L322) > Venture Cam Dock Voltage - Only 1V |
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 207 |
That would be very much appreciated, thanks!! 2010 Range Rover Autobiography TDV8 Santorini Black
8th Jul 2022 8:39pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Sorry mate, didn't get chance, a couple of diag jobs (which are not to be booked in on Saturdays) were, well, booked in...
10th Jul 2022 10:50am |
Oh no problem, thanks!!
10th Jul 2022 2:57pm |
Unless the signalling on MS CAN is different, I can't see why not - I suppose it's possible that the dock isn't getting the 'ignition on' message, that would prevent it working. |
10th Jul 2022 3:48pm |
That was my reasoning too............
10th Jul 2022 8:48pm |
Not really, you want to check each leg to ground, but that will only confirm activity, not the content of the data packets. If you can 'scope each line, you should see something like the photo below on the CAN-H line, the CAN-L will be similar but drop down below the baseline.
10th Jul 2022 9:48pm |
Thanks very much (again!) for the info.
11th Jul 2022 10:33am |
Just been checking my cameras again....... one of the two I had with power in them is now too flat to turn on. However. none of them show any voltage at all across the pins on the camera body (& yes, I tested my meter, with an AA battery). I'll try to find someone in the area with a working cam / docking station and hopefully try their camera in my dock & one of my cameras in theirs. If that works then I'll take the batteries out and try a circuit as per MikeO's post. Cheers Richard 2010 Range Rover Autobiography TDV8 Santorini Black 2010 Range Rover Autobiography TDV8 Zermatt Silver [Gone] 2003 Range Rover HSE Oslo Blue [Gone] 1985 Camel Trophy 90 (Netherlands Team Vehicle) [Gone] 1990 Camel Trophy 127 (Workshop Vehicle) [Gone] 1989 Camel Trophy 110 (Workshop Vehicle) [Gone] 1998 Camel Trophy Freelander (South African Team Vehicle) 1995 Camel Trophy Discovery 300Tdi (Raft Unit) [Gone] |
12th Jul 2022 6:40pm |
Did you get any chance to measure the CAN voltage? |
12th Jul 2022 7:25pm |
Not yet, that will need to wait until I have a chance to get the dash taken apart, again
12th Jul 2022 7:58pm |
Maybe because mine had recently been removed from the dock? There is next to no info on how they interact with the dock other than the IR LED - mine works 'occasionally', which I'm putting down to the 2.4GHz band being saturated in towns.
12th Jul 2022 9:04pm |
Thank-you very much, again!!
12th Jul 2022 9:34pm |
I'm getting the same voltage on both sets of test pads - looks like your PCB has an issue... there is continuity between the -ve pads but a 2VDC differential between the +ve pads which indicates some sort of voltage processing / regulator between the two to me.
12th Jul 2022 9:48pm |
Yep, certainly looks that way.
12th Jul 2022 10:24pm |
