![]() | Home > Technical (L322) > Tow Bar Electronics - 7 Pin -> 13 Pin (2004 4.4 V8) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35610 ![]() ![]() |
you asked the same question in May 2021 and had loads of info... ... - .- -.
hbthepilot Member Since: 21 Mar 2021 Location: Bludenz Posts: 33 ![]() ![]() ![]() |
I know but only parts for L322 newer than 2006 were posted! Still did not find the proper parts and nonody vould tell me if I can keep my existing ECU or if I need a mew one!
ok..if you do a forum search theres loads of info on this.....(thats how i found your previous thread) ... - .- -.
I can’t think of any reason you would need to change the trailer socket ecu, serving one new 13 pin socket is no different to serving the two existing 7 pin sockets. The ecu is still doing the same job.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Or, just use a twin (7 pin) socket to single (13 pin) adaptor lead. No need for the potential of b*gg&r^ng things up. Previous cars:
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
I would leave as is & if you need to tow trailers with 13-pin plugs then use an adaptor.
JamesDarby Member Since: 29 Sep 2021 Location: Rugby Posts: 25 ![]() ![]() ![]() |
Yes you can just rewire the 2 7 pin sockets to a 13 pin. The functions are the same, its just a different plug.
