Home > Maintenance & Mods (L322) > TDV8 4.4 starter motor
Kelso
United Kingdom 2012 Range Rover Autobiography Black TDV8 Java Black
Hi…. I have a 4.4 TDV8 and have the usual starter motor issue. There are cheap ( well cheaper ) starter motors on the market for around £200 or the Denso for around £300.
Are the cheaper ones worth buying and if not where is the cheapest Denso units available from. I will fit the unit myself. Cheers.
Post #635709 29th Jun 2022 10:41am
DrRob
Denso. Use site sponsor Advanced Factors. Discount code is AF4LRP iirc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #635711 29th Jun 2022 10:57am
Baltic Blue
I got mine from Opie Oils when they had a 15% offer on. (Usually at the month end), but if you sign up with them they email when offers available.
Post #635714 29th Jun 2022 10:59am
Baltic Blue
Coincidentally…, I have just received their email, 15% off, code “ JUNE”
You also get free delivery.
Post #635715 29th Jun 2022 11:33am
roel2018
Belgium 2017 Range Rover Autobiography SDV8 Carpathian Grey
How many hours did it took to replace the starter motor?
Post #651076 18th Dec 2022 8:04pm
dhallworth
It can be done in an hour from underneath with only removing the under tray.
It's the easiest starter motor swap I've ever done. Takes a little bit of rotating it until you find the right angle in which it'll come through the subframe but it will and there's no need to remove anything else from the car.
Post #651086 18th Dec 2022 9:45pm
garyRR
That's good to know.
I've really only done short trips this year and now mine is on 150,000 miles, I feel like I'm on borrowed time with the starter motor, expecting it could go at any point. 2015 Range Rover Autobiography 4.4 SDV8
Post #651096 19th Dec 2022 8:56am
roel2018
So, I also get an offer from the official LR dealer for my 2011 TDV8 4.4 448DT.
Labour: € 315 (which means 2,5 hours to replace)
Part LR032541: € 513,02
Including small costs: 889 UK Pounds
You can take also an aftermarket Denso DSN 1207 which is the same I think... And the cheapest way is replacing the solenoid I think but don't know the part no.
This time Land Rover will replace it but I put some extra documents enclosed for the DIY.
Wish you all a good Christmas and greetings from Holland!
Post #651309 20th Dec 2022 8:55pm
