Home > Technical (L322) > Servo replacement help
Jack last
United Kingdom 2005 Range Rover Vogue Td6 Zermatt Silver
Hi all need some help
Has anybody replaced the servo/master cylinder on a td6?
I’m in the process but can’t remove the servo there’s not enough space
Everything is disconnected just can’t lift it out few brake pipes in way can push slightly to side but still tight
Had a look can’t see a guide for this
Anybody done this?
Cheers
Post #572578 12th Nov 2020 12:55pm
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
I did this a good few years back on a 2005 4.4V8 but it is probably the same. I am not certain but I think I may have taken the fitting that connects to the brake pedal off of the servo which gave me the wiggle that I needed to get it out. I know it was very tight but I am sure I did not have to remove anything drastic under the bonnet. I know this is not a great help but at least you know it is doable on the drive way. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #572606 12th Nov 2020 8:18pm
yorkie3259
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Hi jack
assume you managed to do this, I'm just about to start the same job how did you manage. Looks like I may have to remove the device to the left of the master cylinder. Any idea what that part is.
thanks
Ian Do I really have time to tinker with one of these
Post #635573 27th Jun 2022 1:31pm
yorkie3259
Ah just worked out the part I mentioned is the brake booster motor. I guess that's something more used for traction control Do I really have time to tinker with one of these
Post #635575 27th Jun 2022 2:25pm
