Home > Technical (L322) > Suspension U0416-86 (26) Invalid data received from vehicle |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 393 |
Morning all,
26th Jun 2022 8:47am |
So.... just disconnected the CTEK after its been on overnight and went out for a quick drive around the block... all good. No Bongs/errors at all. I also found the 'Speed input Circuit' for the wheels which reported the speed fine as I was driving (will keep looking to see if there are any other settings regarding ABS that can monitored..)
26th Jun 2022 9:44am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8231 |
This faulting at nearly the same time may have an impact.
26th Jun 2022 10:12am |
Hi Pete,
26th Jun 2022 10:35am |
It just needs to know where straight ahead is, make sure the steering wheel is straight as you drive in a straight line, if it's off centre the fatty thinks you are always cornering... Pete
26th Jun 2022 11:31am |
