Home > Technical (L322) > Suspension U0416-86 (26) Invalid data received from vehicle
Superspoons
Morning all,
So yesterday evening drove out in my 2005 4.2 SC and got 1/2 mile down the road when I got the 'bong' and messages on the dash stating 'HDC inactive' / 'Suspension lowering'. All the lights went off the suspension control button to.
Pulled over and switched it off and then on and again, drove another 1/2 mile and the same happened. Once home I scanned it with the IID Tool and found the following under Suspension -
RLM-Suspension
U0416-86 (26) Invalid data received from vehicle dynamics control module - Bus signal/message failure - signal is invalid
( on 25-06-2022 21:13:49 at 81825 mi )
- Test Failed This Monitoring Cycle
- Pending
- Test Failed Since Last Clear
The other faults noted were -
HVAC-Heat / Cool
0x30 Air quality sensor line fault (I have a new part coming for this)
PAM-Parking Aid
0x7 Front centre left ultrasonic sensor (New Sensor waiting to be fitted)
RDUM-Remote Driver
B1A00-46 (D0) Control module - System internal failure - calibration/parameter memory failure
- Test Not Completed
- Test Not Completed This Monitoring Cycle
- MIL Requested
B1A99-4C (D0) Power on reset
- MIL Requested
RLM-Suspension
- Pending
TMC-Traffic Message
B1A56-18 (2F) Antenna circuit - General electrical failure - circuit current below threshold
- Test Failed
- Confirmed
VDM-Vehicle Dynamic
C1B00-64 ( 08 ) Steering angle sensor - Algorithm based failure - signal plausibility failure
( on 25-06-2022 20:57:42 at 81824 mi )
- Confirmed
I've cleared the codes via the IID, carried out a 'Battery Hard Reset' and had the car on my CTEK charger over night in case the battery was low - its a new VARTA battery fitted in Dec' 2021 along with a new Alternator though.
Does anyone have any ideas - from the googling I've done so far I'm thinking ABS / Speed sensor on one of the wheels - how to check the ABS Sensor on each wheel ?
This TSB has proved pretty useful -
https://www.4x4community.co.za/forum/attac...1389629632
The (26) was also (A7) in another scan of the fault codes. Any tips on what to look for in the IID tool live values would be appreciated.
cheers Gavin
Post #635487 26th Jun 2022 8:47am
Superspoons
Update...
So.... just disconnected the CTEK after its been on overnight and went out for a quick drive around the block... all good. No Bongs/errors at all. I also found the 'Speed input Circuit' for the wheels which reported the speed fine as I was driving (will keep looking to see if there are any other settings regarding ABS that can monitored..)
The SC was only driving the day before to get the air con charged up... odd.
 Gavin
Post #635489 26th Jun 2022 9:44am
This faulting at nearly the same time may have an impact.
Worth re-calibrating the steering angle sensor with the IID, see if that helps....
Other than that it seems it's fixed itself... Thumbs Up Pete
Post #635490 26th Jun 2022 10:12am
Superspoons
Hi Pete,
Yes, I did that last night when I got home but forget to mention. It just asked me to position the steering wheel dead centre and then ignition off/on again.. didn't seem to do anything else like move the wheel in/out but it completed the routine successfully.
I guess as you say its fixed itself ... until the next time ... Laughing Gavin
Post #635494 26th Jun 2022 10:35am
It just needs to know where straight ahead is, make sure the steering wheel is straight as you drive in a straight line, if it's off centre the fatty thinks you are always cornering... Thumbs Up Pete
Post #635495 26th Jun 2022 11:31am
