![]() | Home > Maintenance & Mods (L322) > Bleeding brakes advice |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8540 ![]() ![]() ![]() |
IIRC you need a diagnostic tool to bleed the abs pump but I doubt you will need to do that...
The pedal is solid after shutdown and a few pumps to bleed the servo but it's a bit vague when running. I'm changing the front disks and pads next week so may have another go at gravity bleeding. 2012 TDV8 Vogue (L322) |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1299 ![]() ![]() ![]() |
My brake pedal always seemed spongy with quite a bit of travel even though the brakes worked fine. MD just changed the front to rear steel brake pipes and I could now fart on the brake pedal and they work instantly. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1680 ![]() ![]() ![]() |
……….. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
Maybe trip to an MD is on the cards. 2012 TDV8 Vogue (L322) |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic44822.html 2012 TDV8 Black Edition
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
Funnily enough I changed one of my rear calipers today (and have the original genuine stripped down already to refurb and sell on).
…………. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
Do 1 at a time. Close the bleed screw each time you can see air running up the tube and have the tube immersed in brake fluid so, if it back-siphons, it's not taking in air. Once one is done and bled, move onto the next one? That way, you're minimising chances of air getting into the system when you don't have all the tools or 2 people to do it.
JayGee. Nothing special to these brakes so, any garage can bleed them. A note about the front brakes though - my bleed screws on my Brembos have welded themselves to the threads and despite all the heating, cooling, tapping, knocking in the world, there's no chance of getting them out and they just snap. So when you do the front brakes, try and not disconnect them so you don't have to bleed. I was going to Scotland the next day and had to fork out £££ on an aftermarket front caliper from Maltings on an overnight delivery. I have since had that Brembo drilled and re-threaded with M12 breathers (existing bleed screws are M10x1.0) but I had to take it to a proper machining workshop to get it done - the garage managed no more than I could. When they drilled it, you could actually see the metal of the breather valves fused itself into the threads. When I have a 2nd car available, I'll take the other Brembo down to get it drilled and re-threaded and then re-fit both Brembo calipers. I'll probably also change all seals and pistons. 2015 Range Rover Autobiography 4.4 SDV8 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
When the local Land Rover specialist replaced my rear brake pipes and the master cylinder, I had to take it back the following day as the brake pedal was softer than it used to be.
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 729 ![]() ![]() ![]() |
Funny you should say that mj, had a phone call this morning from mj fews as having my front discs and pads changed and i asked if it's worth changing the brake fluid considering I've had both the front and rears done, so thought why not. But then he said it's a real pain to do and may not be the same as before in regards to pedal pressure. I'm not in the UK at the moment to look through the mountain of receipts i have for the car to see when it was last changed, if it ever was, but being an ex robotics technician, I'm a bit anal when it comes to TPM (total preventative maintenance) not tyre pressure monitor lol. |
I don't know why there's this perceived problem with brake fluid changes, it's nothing unusual on any vehicle - there's no special ju-ju involved, it's 'just' pushing sufficient new fluid through each circuit to replace (or in reality, sufficiently dilute) the old stuff. I did my 08MY in May, pushed three litres through it as it was the colour of a hangover p*ss using a Sealey pressure bleeder (lots of dealers of various marques and some independents use them). The only advice I'd give is don't go above 2.5 bar or you risk bursting the reservoir and if you're bleeding a new line or caliper, use the brake pedal to assist the process by pumping a couple of times whilst the pressure bleeder is doing it's stuff.
