![]() | Home > Maintenance & Mods (L322) > Juddering and shaking at WOT |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2222 ![]() ![]() ![]() |
Just swapped the fuel pump and mine is non genuine the new one is genuine. On the genuine one it has a black plug which I have nothing to plug into? I’ve done another post - any ideas if that’s just spare or does it need something in? Is it ok as is for safety
Just an update on this I vaguely remember when the lpg was fitted a couple of years ago and they suggested putting a new filter on while they did the return I bought a genuine lr one and they said there was a plug they didn’t need to use as the pump didn’t have it and it was given back to me in the box with the old one …. Think I forgot and binned it so I have ordered a bearMach filter as it was £28’delivers and has the connection I need. I will stick it on initially to see if the new to me pump and filter fix the issue then I lrevert to the genuine as it has the return already in it. Current stable:
May have jumped the gun the existing one is genuine the stamp was in a different place - but it is the original form 2007 with 130k on it - is this a normal age for them to begin to fail? Current stable:
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8421 ![]() ![]() ![]() |
The 5.0 has the same sort of thing and they say it should be changed at 10 years or 100,000 miles so I guess so.. |
The bearmach filter fuel line to the rail connector on the filter disintegrated as I put it in! The hole was too small and when I pulled it out it pulled out all the o rings too and they went everywhere- what crap.
\\Todays Update//
Dan,
Thanks Pete
Think I'd give it a go, should rule them in or out.... |
My only reservation is I imagine the gases are mega hot - are they likely to melt anything firing out there? Current stable:
EGT is around 400c so not that hot, can't remember which way the o2 sensors face, have a look and see what you think.. |
Afaik the gases will be firing at the back of the pedals… not sure if that’s better or worse Current stable:
Nothing rubber or plastic and you should be OK I recon... Pete
I have a resolution!!!!!!!!
