![]() | Home > Maintenance & Mods (L322) > Juddering and shaking at WOT |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8421 ![]() ![]() ![]() |
Blocked fuel filter would be my immediate guess.... |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2222 ![]() ![]() ![]() |
I’m not saying you’re wrong - In fact it’s a good shout but playing devils advocate, why does it run nicely the rest of the time? Only partially blocked?
You need more fuel at higher revs, it can't supply enough...
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
You say it stinks? in what way?
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3159 ![]() ![]() ![]() |
Our local specialist told me that it’s quite common to see melted cats on the 4.2’s.
That would be incredibly annoying as I changed both last year for low mileage used ones - good idea I have a scope it’s going to get bushes tomorrow so will check over the weekend .
So a little update here i went into the tank and was about to change the filter and or pump I pulled the filter and there is a T for the lpg fuel return - normal… but there was some crap wedged where the bore changed for the T … this would be restricting at higher rpm/load I imagine. I’ve ordered a bigger bore T Current stable:
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1358 ![]() ![]() |
If that smaller bore is designed to be the restriction for the fuel return to satisfy the lpg requirements, you will probably have opened another can of worms unless you have another restricter in the line. |
Already thought of that there was a restrictive screwed into the Tee which I’ve moved into the new Tee Current stable:
Right little lunchtime update… but the new T in with a nice big bore so no restrictions (except where required!)
Where was the popping noise coming from?
I’m not sure maybe the cat or maybe the engine - didn’t sound like a exhaust pop you can force.
My car has an electronic fuel return fitted. When it’s not on LPG it cuts the power to the solenoid so there’s no fuel return. Is yours similar? If it’s returning fuel constantly you will have low fuel pressure. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
