Home > General > Gearbox longevity? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3750 |
Dan, I think you have it.
11th May 2011 3:48pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
i didnt think land rover reckomend an oil change on the 4.4 petrol gearbox so what would be a good mileage for them to be done as i said mines 72 thou so ill do mine anyway "RANGEISM WILL NOT BE TOLERATED"
11th May 2011 4:36pm |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 |
Mines about to hit 50,000 miles and is due next service in just under 10k, so I was planning to look at getting the gearbox oil changed then. FFRR TD6 HSE
11th May 2011 4:42pm |
From day one GM have said their oil must be changed every 50,000 miles, sooner if operated in arduous conditions or under heavy load (towing)
11th May 2011 4:59pm |
I was unaware of GMs and ZFs recommendation on this and to be honest shocked that LR just ignore it! FFRR TD6 HSE
11th May 2011 5:05pm |
There is a BMW memo floating around somewhere that states it's basically acceptable for a gearbox to fail at 100K. It really is disgusting. Initially when I looked into this I couldnt believe LR/BMW do this so I spoke to ZF who confirmed the service interval, but would not comment on "sealed for life"... |
11th May 2011 5:19pm |
Considering the weight of LRs vehicles it should be even more improtant. I bet a good % are used for towing as well. Disgusting is spot on! FFRR TD6 HSE
11th May 2011 5:22pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
I'm sure I read somewhere that one of them (ZF or GM cant remember) is actually rated slightly lower on the torque limit than the engine can provide.
11th May 2011 8:30pm |
Not sure on that as the same box is used on the 4.9l S62 (M5/Z varient of our engine. I want to see one of those in a RR! |
11th May 2011 8:46pm |
Ditto....mines the gm box right? so i need to do this asap "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back " |
11th May 2011 10:12pm |
No, yours is the ZF box. |
11th May 2011 10:18pm |
Dan is right about the fluid changes - with the possible exception for fluid changes on an old gearbox. And disgusting is not a bad way to put it (it's 'ok' for gearboxes to pop at 100k mi because there's no BMW can get stung with repercussions at that point ).
12th May 2011 5:52am |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
I best start saving then, I'm at 90k!!!
12th May 2011 10:17am |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
See this thread http://www.fullfatrr.com/forum/topic4805.html - 20L of Texaco 7045E from Watsons Oil for �66 delivered (enough to do over 3 oil changes and get rid of most of the old oil - I left about 2000 miles between changes). |
12th May 2011 12:08pm |
