![]() | Home > General > Gearbox longevity? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3761 ![]() ![]() |
Dan, I think you have it.
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
i didnt think land rover reckomend an oil change on the 4.4 petrol gearbox so what would be a good mileage for them to be done as i said mines 72 thou so ill do mine anyway "RANGEISM WILL NOT BE TOLERATED"
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
Mines about to hit 50,000 miles and is due next service in just under 10k, so I was planning to look at getting the gearbox oil changed then. FFRR TD6 HSE
From day one GM have said their oil must be changed every 50,000 miles, sooner if operated in arduous conditions or under heavy load (towing)
I was unaware of GMs and ZFs recommendation on this and to be honest shocked that LR just ignore it! FFRR TD6 HSE
There is a BMW memo floating around somewhere that states it's basically acceptable for a gearbox to fail at 100K. It really is disgusting. Initially when I looked into this I couldnt believe LR/BMW do this so I spoke to ZF who confirmed the service interval, but would not comment on "sealed for life"... ![]() |
Considering the weight of LRs vehicles it should be even more improtant. I bet a good % are used for towing as well. Disgusting is spot on! FFRR TD6 HSE
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
I'm sure I read somewhere that one of them (ZF or GM cant remember) is actually rated slightly lower on the torque limit than the engine can provide.
Not sure on that as the same box is used on the 4.9l S62 (M5/Z ![]() ![]() |
Ditto....mines the gm box right? so i need to do this asap "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
No, yours is the ZF box. |
Dan is right about the fluid changes - with the possible exception for fluid changes on an old gearbox. And disgusting is not a bad way to put it (it's 'ok' for gearboxes to pop at 100k mi because there's no BMW can get stung with repercussions at that point |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
See this thread http://www.fullfatrr.com/forum/topic4805.html - 20L of Texaco 7045E from Watsons Oil for £66 delivered (enough to do over 3 oil changes and get rid of most of the old oil - I left about 2000 miles between changes). |
