Home > Technical (L322) > Air suspension query
walkerracing
Hi everyone,
owned my L322 since january. It’s just had some track rod work done and a new rear shock absorber done as part of the majors on the MOT.
Once collected from the garage, drove fine then when i drove it up the road later on to pop to the shops, a suspension max 30 mph warning came up and car went onto its bump stops. Got the car back home and turned ignition off and back on again and reset to normal ride height and all seemed fine. When out to try it on the road later around an hour later and touchwood, all seems to be okay with no warning lights and ride and height are fine.
Is it possible it’s just thrown a wobbly where’s it been jacked up in the garage? Or is this a sign of a bigger problem?
Any advice would be great.
Cheers
Callum
Post #635151 21st Jun 2022 9:36pm
Never had one drop to it's bump stops after being jacked up but they do sometimes take a while to settle down..
See how it goes... Thumbs Up Pete
Post #635154 21st Jun 2022 10:09pm
Phoenix
Do all the ride heights look OK on the 4x4 screen?
It may have been a ride height sensor with a slightly 'sticky' connection to the moving arm not used to articulating to it's extents, dropping to bump stops could have pulled it back into position....
Post #635162 22nd Jun 2022 6:17am
Sandyt
Probably a sensor make sure they are plugged up properly
Post #635164 22nd Jun 2022 7:04am
walkerracing
Thanks for all the advice so far, much appreciated👍🏻
Post #635166 22nd Jun 2022 8:05am
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
I had a similar issue, dropping to the bump stops at random intervals with no specific fault codes. Turned out to be the n/s/r height sensor, the old one was very tight. New one fitted and all good for the last six months. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #635169 22nd Jun 2022 8:56am
