![]() | Home > Technical (L322) > Air suspension query |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8353 ![]() ![]() ![]() |
Never had one drop to it's bump stops after being jacked up but they do sometimes take a while to settle down..
Do all the ride heights look OK on the 4x4 screen?
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 ![]() ![]() ![]() |
Probably a sensor make sure they are plugged up properly |
walkerracing Member Since: 21 Jun 2022 Location: lydney Posts: 3 ![]() |
Thanks for all the advice so far, much appreciated👍🏻 |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 254 ![]() ![]() ![]() |
I had a similar issue, dropping to the bump stops at random intervals with no specific fault codes. Turned out to be the n/s/r height sensor, the old one was very tight. New one fitted and all good for the last six months. 2011MY 4.4TDV8 Autobiography Baltic Blue
