Home > Technical (L322) > L322 4.4TDV8 Westminster Top End Oil Leak |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3176 |
It could be the oi cooler itself, not just the gaskets. it is 2 parts and they have been known to warp slightly, thus leaking oil. I had mine replaced and all is wonderful again. |
20th Jun 2022 2:50pm |
Goodluck247 Member Since: 08 Jan 2021 Location: London Posts: 30 |
Hi, I did wonder that. The only thing that would still be puzzling me is how the puddles of oil are getting up higher than the oil cooler. There is even oil staining to the underside of the engine cover which gives off the impression something is spraying up, even though its unlikely. |
20th Jun 2022 3:03pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4308 |
I'd take it to a recommended specialist for a second opinion. I use www.glenrands.co.uk and nobody else these days. Loan cars or am sure they'd drop you at local railway station. Tell then I sent you Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
20th Jun 2022 4:09pm |
kernokerno Member Since: 12 May 2024 Location: cornwall Posts: 12 |
Hi Goodluck247
14th May 2024 6:03pm |
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 |
Always worth noting that if you just replaced the O rings and gaskets and not the oil cooler, that oil cooler gasket could have failed, been over torqued or was installed slightly off. When I had this issue I took the advice the guys gave me here and replaced the complete unit as it was quite cheap. When I compared the new and the old cooler you could see how oil could leak from a flattened or over compressed gasket.
15th May 2024 7:21am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Carrying on from your previous post If it's like this on the top of the intake and not just down in the 'V' as I assumed I'd look beyond the usual oil cooler leak. As Fla says give it a good cleanup with brake cleaner to narrow down the search area. Oil is present in te intake charge an can cause some misting if there is a leak on teh intake but this looks beyond misting. Can you post some pictures? 2012 TDV8 Vogue (L322) |
15th May 2024 7:36am |
Now that I look at the pictures closer it would also be worth looking at that EGR return pipe and just making sure its not damaged, your intake manifold could also have a crack and the hoses on the 4 pipes going into the doughnut are also well known for failing.
15th May 2024 7:44am |
15th May 2024 10:09am |
The concentration of oil in the one area under the engine cover would be the best clue to the source. 2012 TDV8 Vogue (L322) |
15th May 2024 10:26am |
So looking at the engine cover LHS where it clips onto engine is where the highest concentration of oil is deposited |
15th May 2024 10:32am |
Check the front of the engine and in particular any oil contamination on aux drive belt ( Any squeal on startup?) as this is also the area of the oil pump which can be prone to leaks and it may be throwing oil up. 2012 TDV8 Vogue (L322) |
15th May 2024 10:47am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1234 |
Somewhere on this site there is a mention of a bolt or plug that comes loose near the back of the oil pump/vacuum pump that needs taking out and resealing. It's hard to see though. |
15th May 2024 11:14am |
Just like to mention due to health issues been unable to look at this problem for quite some time, so oil has had plenty of time to spread from original leak location.
15th May 2024 11:21am |
You can buy 5L quantities of brake cleaner and a specific brake cleaner sprayer bottle and this will clean everything down nicley. Fingers crossed the leak is on the oil pump as this is an easier job than replacing the intake gaskets. 2012 TDV8 Vogue (L322) |
15th May 2024 11:36am |
