Home > Maintenance & Mods (L322) > Windscreen protection and insect damage - Driving in Europe
Kot
oggy wrote:
put 30 ml of ipa in spray bottle fill with pure water or filter water in a 500ml sprayer very good for ripping the guts off also use for cleaning the rest of the windows you will not use anything else use microfiber cloths .
also for the washer bottle i mix 5 ltrs up i use 50 ml of sonax and put in 20 ml of ipa fill up with filter water deionised water i always use this water when i wash the car on the final rinse no more streaky body
panels or glass
is that IPA "India Pale Ale" Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #635054 20th Jun 2022 1:29pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
i had a feeling that someone was going to come back and say that i had to make it short because i could not spell the full name of it new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #635069 20th Jun 2022 4:32pm
Weegie
No surprise. You couldn’t even spell name. Wink Rolling with laughter Rolling with laughter John
GAP iiD BT-Sold
Post #635071 20th Jun 2022 4:58pm
oggy
just in case of people thinking what is ipa it is short for isopropyl alcohol new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #635080 20th Jun 2022 6:43pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
jez000 wrote:
Hi AJA, apologies I did say I would ask the guys who did my PPF about a product called ClearPlex which is a PPF for windscreens - it might be worth a look. Im back at REEP next friday so will ask about its suitability for a heated RR screen.
https://www.reepsouthern.co.uk/clearplex/
Just spoke with them - £500+VAT for Clearplex - can go on heated & solar screens without an issue - its a lot of money but my L322 was never the same after having a new windscreen fitted and leaked within 3 months of replacement. 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #635186 22nd Jun 2022 3:56pm
oggy
the main problem that windscreen leak it is not the bonding of screen to frame it is the clips that hold the a pillar covers on they have got to be replaced with new clips with the seal rubbers on even if the old ones come out put them in a bin replace with new . i always remove all covers and replace them myself after 24 hours of windscreen being fitted if you want a job doing right do it yourself new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #635197 22nd Jun 2022 6:46pm
I like and use many Sam Som products and find Bugsy is excellent at bug and bird muck removal. Spray on direct from the bottle, leave for a minute or two and just wipe away with a soft cloth or paper towel. Its what I use between proper cleans if the car gets splurged.
https://sansom.co.uk/products/bugsy_750ml Mike - MPx
Post #635199 22nd Jun 2022 7:11pm
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
It's particularly bad when driving through France at dusk and during the night.
I've always just stopped at services and cleaned the windscreen properly. 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #635201 22nd Jun 2022 7:21pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I clean my screen with 000 wire wool and detergent to get it as clean as possible then I use one of the cheap ebay ceramic coatings. This last a good 6 months, water just beads off once moving so hardly use my wipers for rain. A damp cloth removes bugs and other contaminants. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #635240 23rd Jun 2022 1:13am
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
If you're the pre-emptive type, a RainX treatment on the screen will ease the whole process for at least a month
 "it needs some intelligence to undestand you may not have enough"
Post #635364 24th Jun 2022 4:01pm
