Home > Technical (L322) > Replacement starter motor issue
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Hello, I finally had the starter issues that have been mentioned many times on here.
I bought last week what I thought was the correct replacement but now having got the old one out the solenoid is in a different position. I don't know if my original is incorrect or the replacement. Has anyone come across this before ?
It's a late 2012 TD V8 Westminster
I haven't tried to see if it might fit as I don't want to get it dirty if it should have to be changed so thought I would ask here first, thanks.
Having just re-looked at what I ordered on the opie oil site by my numberplate, it might be for a later SDV8 Sad
[/img]
Post #634314 11th Jun 2022 11:03am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
i have a 4.4TDV8 that every now and then would just click and thought it may be the starter issue. any how before i got to change the starter out my battery failed so replaced that. since then it has not happened!!! 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #634316 11th Jun 2022 11:32am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I think you will find the same bottom-end so should be the same as 2010 onwards? I believe that the 4.4 v8 were all the same engine maybe they have given you one for a 3.0
model?
Post #634318 11th Jun 2022 11:39am
4040
Having looked into it in more detail Opies web site....
On entering my reg no it comes up with a choice, standard or stop/start. So I ordered DSN1420, a non stop/ start
When I enter just the year, model etc it comes up with DSN 1207 which is obviously a different part no, which is I guess they one I should have ordered, so I think I will wait until Monday and give them a call to hopefully sort it out, thanks
Post #634319 11th Jun 2022 11:55am
4040
If anyone could confirm what there part no was for a 2012 one, that would be a help to
Post #634320 11th Jun 2022 12:03pm
Tinman
The main problem with the starter is the solenoid the contacts get carbon build-up which can be cleaned off?
My starter took off 2012 AB
Post #634322 11th Jun 2022 12:08pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
You need a DSN 1207.
Post #634323 11th Jun 2022 12:17pm
4040
Thanks for the replies.
Just to update. Opie oils could not provide a match for my original starter motor. They were very good and refunded with no problems at all. They also got in touch with Denso and they also could not provide a match between the previously mentioned Dsn 1207 starter and the part number of mine.
So in the end I bought one direct from LR just to get it back on the road. (Which exactly matched mine) Less than 24 hrs after ordering it’s all fixed now.
I do wonder if the very last 2012 ones are different?
By the way, it absolutely would not come out by the method I have read on here via the anti roll bar gap. It’s a least 10mm bigger which ever way you try it.
In the end it came out through the triangular gap in the lower subframe fairly easily, though it was a bit harder to get the new one in a couple of days later with no gravity to help !
Post #634636 14th Jun 2022 8:01pm
Sarchopperman
United Kingdom 2011 Range Rover Vogue TDV8 Epsom Green
I had a similar problem. Opie oils website identified my 2012 TDV8 4.4 L322 as an L405 and supplied a Denso Starter DSN 1420. I have a 2011 TDV8 4.4 which Opies site correctly identifies and provides the DSN 1207.
Opie have been really good and there is much confusion over these late L322's that are identifying as L405's.
If you have a 2010 to 2012 L322 (Mk III) TDV8 4.4, you need a Denso DSN 1207 starter motor. I hope this helps.
The starters look very similar as shown in the photo. One fits, the other does not. RR L322 TDV8 4.4 SE 2019 to present
RR L322 TDV8 4.4 - 2016 to present
Discovery 2 TD5 - 2010 to 2016
Discovery 1 - 2000 to 2010
Post #645963 19th Oct 2022 4:55pm
