Home > Technical (L322) > Gearbox Overheat - 4.4 TDV8 |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 761 |
Pulled the caravan a couple of hundred miles last Thursday without any issues. Toured about for another couple of hundred miles on Friday and Saturday, no problems.
7th Jun 2022 12:38pm |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
You had a megaflush, was the oil pan replaced? Christian.
7th Jun 2022 12:42pm |
No ideas! Will need to ask 'Mikey' (MMP4x4), as he's the one that did it.
7th Jun 2022 12:54pm |
The oil pan has swarf magnets and a built in oil filter.
7th Jun 2022 1:20pm |
As I understand it, the filter was changed at the same time as the megaflush. The older I get, the more I realise that people confuse wrinkles for wisdom |
7th Jun 2022 4:38pm |
Any idea how the process works then?
7th Jun 2022 4:43pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
I had to have my transmission cooler valves replaced as they had seized.
7th Jun 2022 7:21pm |
200+ miles of towing without issue yesterday. Fifteen miles of normal A-road driving on Sunday and it threw a spurious alert which hasn't happened again. The older I get, the more I realise that people confuse wrinkles for wisdom |
7th Jun 2022 9:07pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
There is a transmission oil temperature sensor in the Mechatronic pack, there is also a secondary transmission temperature calculation carried out based upon calculated load.
7th Jun 2022 9:34pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
If you have an IID tool, you can set it to data log transmission oil temperature.
7th Jun 2022 10:20pm |
Thanks for the insights chaps!
8th Jun 2022 12:28pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Maybe best to use the brakes for slowing down on a hill while towing as that's a lot of kinetic energy to dissipate in the gearbox. 2012 TDV8 Vogue (L322) |
8th Jun 2022 12:33pm |
I wasn't towing when it happened - just out for a Sunday drive! The older I get, the more I realise that people confuse wrinkles for wisdom |
8th Jun 2022 4:20pm |
