![]() | Home > Technical (L322) > Gearbox Overheat - 4.4 TDV8 |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 779 ![]() ![]() ![]() |
Pulled the caravan a couple of hundred miles last Thursday without any issues. Toured about for another couple of hundred miles on Friday and Saturday, no problems.
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
You had a megaflush, was the oil pan replaced? Christian.
No ideas! Will need to ask 'Mikey' (MMP4x4), as he's the one that did it.
The oil pan has swarf magnets and a built in oil filter.
As I understand it, the filter was changed at the same time as the megaflush. The older I get, the more I realise that people confuse wrinkles for wisdom |
Any idea how the process works then?
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
I had to have my transmission cooler valves replaced as they had seized.
200+ miles of towing without issue yesterday. Fifteen miles of normal A-road driving on Sunday and it threw a spurious alert which hasn't happened again. |
There is a transmission oil temperature sensor in the Mechatronic pack, there is also a secondary transmission temperature calculation carried out based upon calculated load.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
If you have an IID tool, you can set it to data log transmission oil temperature.
Thanks for the insights chaps! |
Maybe best to use the brakes for slowing down on a hill while towing as that's a lot of kinetic energy to dissipate in the gearbox. 2012 TDV8 Vogue (L322) |
I wasn't towing when it happened - just out for a Sunday drive! |
