![]() | Home > Technical (L322) > Replacement Air Suspension Compressor - SDD Coding? |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3162 ![]() ![]() ![]() |
Whilst removing the LPG from my L322 I've purchased a replacement EAS compressor in the metal tortoise shell to go where the LPG tank was.
Does anybody know: 1. Is the relay just a new relay the same as the LR one or is it uprated? 2. What is the ECU update? Is it something I can do with my IID tool if I purchase a firmware update from GAP? Thanks, David. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather 2012 Range Rover 5.0 SC Autobiography in Indus Silver with Jet/Ivory Interior 2012 Range Rover 4.4 TDV8 Autobiography in Baltic Blue with Sand Interior |
The relay change is 'standard', not just on LR stuff, it's basically to ensure there is no volt-drop in the supply to the compressor that may lead to early failure. As most compressors are / were changed due to some sort of problem, it makes sense to change the relay at the same time. It should just be a 4 pin 70A one. |
Thanks.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8436 ![]() ![]() ![]() |
Dave, why are you removing the LPG...?? Pete
Pete,
That males sense, should be as good as new now then... |
vektory Member Since: 27 Feb 2023 Location: Vienna Posts: 21 ![]() ![]() ![]() |
Bringing this topic back up as my problems are becoming more and more...
Okay - so I went for the P-3232 and ordered the IID Tool as it might come in handy more often
