Home > Maintenance & Mods (L405) > Secondary turbo shut off valve |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
My L322 4.4 tdV8 CSOV was replaced under warranty.
5th Jun 2022 11:32am |
Pat Member Since: 20 Nov 2016 Location: Airdrie Posts: 55 |
Hi Thanks for your reply. Its not the CSOV that the fault I have already had that out and tested. This valve is bolted to the back of the passenger side turbo |
5th Jun 2022 12:06pm |
Hi I will try and attach photo |
5th Jun 2022 12:13pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35263 |
5th Jun 2022 12:17pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
Just out of curiosity what are the symptoms / error? Given it’s on back order might mean it’s fairly common. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
5th Jun 2022 4:27pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
It's item 5 in the below image. Part number is LR027196.
8th Jun 2022 10:27pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 798 |
That part number is superseded by
18th Jun 2022 6:55am |
Also interested to know what the symptoms are ….. |
18th Jun 2022 7:15am |
Hi thanks for getting back to me. My symptoms were a restricted performance warning every time i took car above 2800RPM. This is when secondary turbo should kick in but as the valve is faulty it was triggering a fault resulting in restricted performance mode. This was confirmed by a reputable independent LR specialist. The first garage I went to wanted £8100 to replace both turbos needless to say I wanted a second opinion and they told me after much investigation it was the "Turbine Valve" on the secondary turbo. This was confirmed in March 22 and as of today I am still waiting for them to get in touch when they receive the new valve. I contacted LR myself re the valve and they said I could order (and pay) for one but could not give me a delivery date. |
18th Jun 2022 9:41pm |
Not sure if the engine operation changed that much between the L322 and L405 from 2012 model to 2013
19th Jun 2022 5:40am |
It is 2400 rpm on the L405 SDV8 also. Kev
19th Jun 2022 6:56am |
So latest update on my turbo issue. Having been told I would have to wait forever on the part I need I decided to try for a used one from an online breakers. Got reply from a well known one via a phone call. Basically telling me that this part would not solve my issue. They guy said I had carbon build up on the veins on my VVT and only solution was to remove the turbo and have it completely refurbed (cost between £295 and £495). I suggested to him that it was only the primary turbo (Drivers side on RHD) that was a VVT and the secondary was a "normal" turbo. He then said if one was VVT then both would be. I am now completely confused.
21st Jun 2022 7:14pm |
You are correct. Only the primary is a VGT (variable geometry turbocharger) and this is the offside one. Secondary is fixed vane type and this is the nearside one. Kev
21st Jun 2022 7:20pm |
To visually clarify...
21st Jun 2022 7:25pm |
