Home > Maintenance & Mods (L405) > Secondary turbo shut off valve
Pat
Scotland 2013 Range Rover Autobiography SDV8 Causeway Grey
Hi I have been told I need a new Turbine shutoff valve (Turbo shut off valve) on my secondary turbo on my 2013 L405 4.4 SDV8. My garage and LR Dealer both say they are on back order (Since February 22).Has anyone ever heard of this and better still has anyone ever done this job. Tricks and tips would be greatly appreciated .
Post #633724 5th Jun 2022 11:15am
Baltic Blue
My L322 4.4 tdV8 CSOV was replaced under warranty.
It’s any easy job, 1 hour max.
Service bulletin giving full details in Wiki.
Post #633725 5th Jun 2022 11:32am
Pat
Hi Thanks for your reply. Its not the CSOV that the fault I have already had that out and tested. This valve is bolted to the back of the passenger side turbo
Post #633726 5th Jun 2022 12:06pm
Pat
Hi I will try and attach photo
Post #633727 5th Jun 2022 12:13pm
Thumbs Up ... - .- -.
Post #633728 5th Jun 2022 12:17pm
TJH1985
Just out of curiosity what are the symptoms / error? Given it’s on back order might mean it’s fairly common. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #633746 5th Jun 2022 4:27pm
knwatkins
It's item 5 in the below image. Part number is LR027196.
No idea on how difficult it is to replace though sorry. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #634099 8th Jun 2022 10:27pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
That part number is superseded by
LR066428
Post #634893 18th Jun 2022 6:55am
Rambles
Also interested to know what the symptoms are …..
Post #634894 18th Jun 2022 7:15am
Pat
Hi thanks for getting back to me. My symptoms were a restricted performance warning every time i took car above 2800RPM. This is when secondary turbo should kick in but as the valve is faulty it was triggering a fault resulting in restricted performance mode. This was confirmed by a reputable independent LR specialist. The first garage I went to wanted £8100 to replace both turbos needless to say I wanted a second opinion and they told me after much investigation it was the "Turbine Valve" on the secondary turbo. This was confirmed in March 22 and as of today I am still waiting for them to get in touch when they receive the new valve. I contacted LR myself re the valve and they said I could order (and pay) for one but could not give me a delivery date.
Post #634975 18th Jun 2022 9:41pm
Rambles
Not sure if the engine operation changed that much between the L322 and L405 from 2012 model to 2013
In the L322 4.4 tdv8, the 2nd turbo comes on at 2400 rpm
Post #634982 19th Jun 2022 5:40am
knwatkins
It is 2400 rpm on the L405 SDV8 also. Kev
Post #634984 19th Jun 2022 6:56am
Pat
So latest update on my turbo issue. Having been told I would have to wait forever on the part I need I decided to try for a used one from an online breakers. Got reply from a well known one via a phone call. Basically telling me that this part would not solve my issue. They guy said I had carbon build up on the veins on my VVT and only solution was to remove the turbo and have it completely refurbed (cost between £295 and £495). I suggested to him that it was only the primary turbo (Drivers side on RHD) that was a VVT and the secondary was a "normal" turbo. He then said if one was VVT then both would be. I am now completely confused.
1: Is primary turbo on drivers side
2: Is that only turbo that is a VVT
Any help on info would be much appreciated
Post #635135 21st Jun 2022 7:14pm
knwatkins
You are correct. Only the primary is a VGT (variable geometry turbocharger) and this is the offside one. Secondary is fixed vane type and this is the nearside one. Kev
Post #635136 21st Jun 2022 7:20pm
knwatkins
To visually clarify...
 Kev
Post #635138 21st Jun 2022 7:25pm
