Home > Maintenance & Mods (L322) > 2007 TDV8 3.6 engine whine. Help, I'm 300 miles from home!
FJ12Jagmen
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Travelled from Essex to Peebles yesterday. As we crossed the border I noticed a whine coming from the engine when slowing down. Heard the same noise last time I crossed the border, turned out to be the alternator. Changed by my indie for a genuine LR one.
Probably drove another 100 miles since, whine seems louder. No problem starting or engine running, in fact she seems to be running better than ever.
IID tool shows battery voltage 12.6 at rest, 13.7 at idle and 14.5 to 14.7 at 1500rpm.
Loading the alternator with all lights heated screens etc shows no difference in readings. Full bore with AC makes no difference to the noise or readings.
Power steering all good, fluids correct.
No burning rubber smalls and from what I can see belt is fine.
I'm thinking idler pulley(s) bearing. Has anyone had a pulley fail and take the belt with it?
Will it get me back to Essex is the ultimate question?
Any ideas gratefully received.
Post #633681 4th Jun 2022 1:30pm
Sandyt
I would say go for it you should get home one of my pulleys whined for about 2000 miles before I got round to changing it and I was in the south of France when it started
Post #633689 4th Jun 2022 4:06pm
FJ12Jagmen
Many thanks that's very re-assuring. I'll turn the radio up.
Post #633707 5th Jun 2022 1:15am
dhallworth
Have you got breakdown cover? If so, I'd chance it Smile
If not and you break down half way it could get expensive. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #633761 5th Jun 2022 10:21pm
Range Rover L322
I would go for it! These cars are awesome and robust and look after us.....
...however this is me stuck on the A31 last summer.... there are worse places to spend 5 hours.
 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #633765 5th Jun 2022 11:33pm
FJ12Jagmen
Yep got cover. Lovely spot bet I'm not that lucky. Thanks all.
Post #633777 6th Jun 2022 9:39am
FJ12Jagmen
Made it home. Stripped the rad cowling etc and found a very noisy idler (the large one. Replaced - no noise. It would probably have gone quite a few more miles.
Whilst I had some of the water out of the system decided to tackle the heater control valve. Simple job but blooming awkward, lying on top of the engine. Longer arms would have helped. Needed 1/4" drive rachet on the jubilee clips even then could only turn 1/8 at a time. The valve does just pull apart after releasing the bolts but was very tight. The piston bit was tight to start with, wiggling loosened it off. Lubed with rubber grease and put back together. When replacing on the car I ensured the jubilee clips were turned and can now be reached with an extension bar.
Refilled system and bled - easy to say but what a PITA. Anyway no leaks and quiet engine.
Post #634350 11th Jun 2022 4:23pm
Glad it's sorted, they usually get you home... Thumbs Up Pete
Post #634361 11th Jun 2022 7:11pm
Yes glad she got you home sir... Thumbs Up Bow down Thumbs Up
Post #634379 12th Jun 2022 12:46am
