![]() | Home > Maintenance & Mods (L322) > Rust comes back after a month.. |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 ![]() ![]() |
I’m not too familiar with the products you’re using, but to me it looks like solvent popping. 😎🇦🇺 |
I should’ve said could also be moisture in your airline did you have a water trap on your gun, airline, compressor? |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
I used a rattle can so no moisture hopefully- shall I just flatten them back and leave for a month to see what happens? Current stable:
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
when i first got mine some one had done it small area of bubbles so took the grinder and cut it right out take a good area out as it will have spread i weld stainless plate back in . and take rear light out remove the grommet push the felt padding back out of the way and pump in a good ltr of wax protector when you have done all your top coats one good thing the bumper shows no sing of rust |
Go back to the start, you’ll need to sand the bubbles back to bare metal (unfortunately) and start the preparation again. Is the base metal aluminium? |
Good job Oggy, you are working on mild steel yes ? Did you use etch primer on the new metal repair , then use a sealer? Welding dissimilar metals has been know to cause rusting quicker in some instances, but if you sprayed a heap of fish-o-lean inside the panel you may have better chance of it lasting a long time. Just saying |
just to add the rust is coming up from the bottom if you remove the bumper the bracket that holds the bumper on the side you can just see it remove that and look up that is wear the water is lying and rusting on that return get in there with a dremel and cut a slot it is mild steel . you could get away with fiberglass filler if you can not weld yourself to stitch a patch in . new vehicle purchase
hi yes metal and i always use epoxy resin on top of my weld plates a couple of coats then i key epoxy with 60 grit just a key and then on with a coat of bridger gap fiberglass filler and then finish with a polyester filler to shape . then i use 1k prima 3 coats when dry you must put a guide coat over primer best to use black colour to take out any shrinks or low spots be for you base coat . leave guide coat on to dry overnight flat that coat with 500 dry then finish with wet flat with 2000 panel wipe on with the base coat new vehicle purchase
I see you're in Padstow - how much 'environmental protection' are you using when carrying out the repairs? are all the repair materials (including the 60 grit) new and unused on anything else?
all good down in padstow in cornwall very busy new vehicle purchase
I have just used some 400 grit to flatten back and they have disappeared- I will try one more top coat in case it was gas’s escaping Current stable:
Yea so they didn’t work it has bubbles up and is brown…
morning take a picture of the new rust that is coming through let's have a look new vehicle purchase
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8553 ![]() ![]() ![]() |
Over my near 50 years of car ownership, and a plethora of rusting hulks, may I offer my 2p worth....
