![]() | Home > Maintenance & Mods (L322) > low range wont engage TD6 |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 ![]() ![]() |
G’day littlecub, i had same problem a few weeks ago, i ended up putting the SC on it and cleared the Low range code and all good again.
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 ![]() ![]() ![]() |
Hi Googs, thanks for your response.
G’day littlecub, did you get rid of soft heater code?does the main fan function?
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
got my HI /LO stuck inbetween the two last week , pulled the TB motor and one of the magnets inside had come away jamming the motor up , i manually set the car to HI so i can keep using it but need to sort the magnet issue at some point |
Hi Googs,no I didnt but heater still works,not sure about fan.
What scan tool do you have?
Got an iid tool Goog,s, it clears a lot.
So when you drive off you are stuck in low range?
Hi Googs,
Thanks littlecub, I will have a look and yes I’m not familiar with them.
