Home > Maintenance & Mods (L322) > Fuel jet pump 4.2
Danwilderspin
Fuel jet pump 4.2
So I’ve kindly been given a fuel pump for my 4.2 which is great as they my next suspect - i was told this pumpworked but didn’t pump one side of the tank - it’s only a couple of years old and genuine lr so want to give it a go.
It looks like there’s only one motor / pump so I can’t understand how it can pump one side but not the other? Any ideas?
I put 12v on the pump for 10 seconds it sounded right didn’t want to burn it out so they was enough Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633353 31st May 2022 1:41pm
rjff
Dan
If it's the same pump as used on the 2011MY 4.4 then there is only one pump, in the bucket fitted on the drivers side of the tank.
This pump, IIRC, provides fuel to the engine bay and with enough additionaly to a jet unit in the nearside of the tank which fills the drivers side as the tank empties. Thus there should be two parts attached by cables and pipes. The pipes are a supply from the electric pump to an jet (eductor) unit and a return to the "bucket" containing the pump itself.
There should be two level gauges/sensors.
I think that's a fair description of operation, but stand to be corrected. Cheers
Richard
Gap IIDBT
Post #633359 31st May 2022 2:44pm
rjff
There's a good diagram in the WM under
fuel system
tanks and lines
components Cheers
Richard
Gap IIDBT
Post #633361 31st May 2022 2:57pm
Danwilderspin
It looks like what you say but what I don’t understand is why he said the jet pump side failed 😆 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633378 31st May 2022 5:35pm
rjff
My suggestion would be to check the pipes, joints, and anything else you can think of for leakage and tightness, as well as any possible blockages.
If you are brave you could try dunking it in a couple of small buckets and seeing if the jet pump side works. (that may be "interesting" with petrol Shocked ) Cheers
Richard
Gap IIDBT
Post #633399 31st May 2022 8:12pm
Danwilderspin
Sorry if this is a really dumbe question but could I test this with buckets of water? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633613 3rd Jun 2022 12:21pm
rjff
I would think so as petrol isn't the best of lubricants, thus I would expect the pump to work without to much detrimental effect while you test it. Cheers
Richard
Gap IIDBT
Post #633617 3rd Jun 2022 1:03pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I'm not sure how it works or what breaks, but the pump only pumping from one side is a common fault and the solution is generally a new pump assembly - happened to mine years ago on the M40, resulted in a stranded wife!
Post #633696 4th Jun 2022 7:38pm
Danwilderspin
What’s the temporary solution keep over 70 miles in the tank? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633721 5th Jun 2022 10:50am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Yes Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #633731 5th Jun 2022 1:28pm
