![]() | Home > In Car Electronics (L322) > Whats going on here then ? |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 394 ![]() ![]() ![]() |
Hi,
Thanks Mike - what would this affect in the car ? Phone pairing ? Rear Screen Headphones although I think they are Infra Red on my model ?
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Rear screen headphone use the transmitter in the headlining, as you say, infrared.
...I've not tried yet but will give it a go - thanks for the info. Gavin 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
It only effects the Bluetooth.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 903 ![]() ![]() ![]() |
Yep, the orange "wire" in the loop is a fibre link bypassing the Bluetooth module since its a common failure.
Thanks all.
I seem to remember that someone on this forum used to offer a repair/upgrade service to the BT unit.
It's about £100 for one but 2nd hand Nokia units are c£70! The unit is much more reliable though and was what is fitted in the later Range Rovers and Discoveries. 2015 Range Rover Autobiography 4.4 SDV8 |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 595 ![]() ![]() ![]() |
Try searching for a Range Rover Sport module, I found mine last year for £50. It was from a 2012 model.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3146 ![]() ![]() ![]() |
My old Nokia module was also bypassed when I bought my L322. I took it out and it looked fine until I opened it up and it was green inside it.
Thanks all.
Yep, Bluetooth units are 100% plug and play and take seconds to swap out.
Yes - a nice get out clause.
