Home > In Car Electronics (L322) > Whats going on here then ?
Superspoons
Hi,
Whilst clearing out the back of my 4.2SC I discovered this... Can someone fill me in on whats happened here to result in this, er, repair ?
Thanks Gavin
Post #633236 30th May 2022 11:53am
mpirie
That looks like the common bypass fix for a failed Bluetooth module where the fibre connections are removed from the module and a replacement fibre inserted to allow the rest of the AV system to work.
The black box at the top of the stack is the BT module.....those fibre's should plug in to it.
Mike
Post #633240 30th May 2022 12:13pm
Superspoons
Thanks Mike - what would this affect in the car ? Phone pairing ? Rear Screen Headphones although I think they are Infra Red on my model ?
Thanks Gavin
Post #633248 30th May 2022 1:14pm
mjdronfield
Rear screen headphone use the transmitter in the headlining, as you say, infrared.
I’m assuming you can’t pair a phone to the car like that? Might be wrong…
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #633251 30th May 2022 2:22pm
Superspoons
...I've not tried yet but will give it a go - thanks for the info. Gavin
Post #633253 30th May 2022 2:49pm
garyRR
It only effects the Bluetooth.
The Nokia unit is notorious for corroding and failing, in turn stopping the whole system working properly because it works on a fibre optic loop. Obviously, Bluetooth won't work.
If you want Bluetooth again, you can buy the much more reliable Ford-designed unit. The part number is 8H22 10F845 AA. 2015 Range Rover Autobiography 4.4 SDV8
Post #633256 30th May 2022 4:02pm
mpirie
Yep, the orange "wire" in the loop is a fibre link bypassing the Bluetooth module since its a common failure.
So you won't be able to pair your mobile with the car until the Bluetooth module is back in the chain.
Sometimes the module fails because of corrosion, so if you are of a mind, you could take it out and see if it's repairable before replacing it.
Mike
Post #633277 30th May 2022 6:59pm
Superspoons
Thanks all.
I think I'll take it out and have a look inside after looking at the prices of the Ford unit (thanks the part number GaryRR Thumbs Up ) Gavin
Post #633312 31st May 2022 8:07am
mpirie
I seem to remember that someone on this forum used to offer a repair/upgrade service to the BT unit.
Mike
Post #633319 31st May 2022 8:40am
garyRR
Superspoons wrote:
Thanks all.
It's about £100 for one but 2nd hand Nokia units are c£70!
The unit is much more reliable though and was what is fitted in the later Range Rovers and Discoveries. 2015 Range Rover Autobiography 4.4 SDV8
Post #633325 31st May 2022 9:31am
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Try searching for a Range Rover Sport module, I found mine last year for £50. It was from a 2012 model.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #633333 31st May 2022 10:19am
dhallworth
My old Nokia module was also bypassed when I bought my L322. I took it out and it looked fine until I opened it up and it was green inside it.
If you're not in a rush, keep looking for the newer model on eBay as they do regularly come up for around 50 quid.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #633335 31st May 2022 10:26am
Superspoons
Thanks all.
In no rush so will take a look inside my one and if I cant get it working, look for a later one.
I've seen some on eBay - they say 'needs coding' .. surely these are just 'plug and pray' ? Gavin
Post #633342 31st May 2022 11:33am
dhallworth
Yep, Bluetooth units are 100% plug and play and take seconds to swap out.
I always wonder if "Needs Coding" is their way of saying it doesn't work! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #633343 31st May 2022 11:34am
Superspoons
Yes - a nice get out clause.
Do the newer units give any extra functions over the earlier ones - apart from being better designed ? Gavin
Post #633344 31st May 2022 11:39am
