Home > Technical (L322) > Radio Code |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 |
What I mean is after you enter the 4 digits what do you do next? |
24th May 2022 9:08am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
I don’t think it has a radio code.
24th May 2022 10:24am |
This is what i have been doing, so I’m guessing that the radio amplifier is toast (in the boot)
24th May 2022 7:36pm |
The amplifier won’t cause this issue I don’t think. A couple of members have had the car do this after disconnecting battery, and I think the emergency deactivation worked after a few tries. Ignition on, and a countdown from 10 or 15 minutes starts… you wait and then should be ok. From memory that…
24th May 2022 8:15pm |
This is what I was looking for….
24th May 2022 8:43pm |
Thank you, i will give it a try just to get myself familiar with the system……a plastic bag aye, geez that inventive !!
24th May 2022 9:27pm |
Everything is controlled from the boot. The screen is literally just a screen, with a tape deck behind it.
24th May 2022 9:41pm |
So if the orange light isn’t glowing above the left side rotary knob does this mean the screen is toast or the radio amplifier?
25th May 2022 8:14am |
So the orange light above the LH rotary knob is that controlled by the radio unit in the boot OR the screen ? |
27th May 2022 2:12am |
