Home > Technical (L322) > 4.2 SC Huge amount of gray smoke on startup - 118,000 miles
Glibbs
Good morning,
The subject says it all really so any thoughts short of engine replacement gratefully received but that said, how much would a new/recon engine cost?
It has a full service history.
TIA. Range Rover 4.2 SC
2 Range Rover Classics - one from new but both rusty now.
Rover 3.5 Coupe had since new.
Subaru Legacy 3.0.
BMW K1200RS.
Post #632628 23rd May 2022 9:21am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Only on startup?
Normally points to valve stem seals. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #632629 23rd May 2022 9:24am
Glibbs
Thanks for your reply.
I think it's probably worse than that. When I said huge amount of smoke, I could hardly see through it. Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #632630 23rd May 2022 9:27am
Glibbs
Spoke to the garage and he thinks I've put diesel in it but would the spout from the pump fit the filler on a petrol car? Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #632635 23rd May 2022 10:05am
Caesium
The diesel spout is bigger than the unleaded one.
Mine is diesel so I can’t check the size on mine. Diesel will make the car run really rough as well, not just on startup Christian.
Current Cars
2019 BMW X4
or
Post #632637 23rd May 2022 10:29am
Glibbs
I didn't run it for long and the smoke did reduce a little. I put about 45 litres in it to fill up.
Is there a way to find out if the wrong fuel had been put into BP own tanks as I'm pretty sure they wouldn't admit it?
The RAC is coming out so fingers crossed it's just a miss-fuel. Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #632640 23rd May 2022 10:49am
dhallworth
If they'd put the wrong fuel in the tanks there'd be a queue of broken down cars not far from the garage I'd imagine.
Be interested to see what the AA find though. They'll have something to suck a sample of fuel from the tank I'd have thought.
When stem seals fail you usually get a puff of blue smoke on a cold start and I'd imagine you'd have that for quite a while before you start seeing clouds of smoke from the back. Could be wrong though!
Post #632658 23rd May 2022 12:37pm
strongstuff
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Have a look around your PCV valve, mine had a problem where it was sucking oil out of the engine through the valve and then into the throttle body.
This is a documented failure on Jag forums.
I replaced the PCV, twice, which didn't cure it, there's an updated pipe that goes from PCV to throttle body.
Mine was as you describe, really thick nasty light grey smoke.
PCV Valve To Inlet Breather Pipe 4.2 SC (Genuine) 4696662 4629174 (4696662LR)
I got my pipe from Island. 2008 L322 4.2 V8 SC Stornoway Grey
2006 L322 4.2 V8 SC Java Black
Post #632680 23rd May 2022 2:17pm
Glibbs
The RAC have been and it's not diesel so I'm going for your PCV pipework recommendation as my Indie can't 'see' it for three weeks.
Many thanks to all and much appreciated.
Barrie Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #632683 23rd May 2022 2:23pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Caesium wrote:
Only on startup?
Are stem seal a "a thing" on 4.2s?
Post #632694 23rd May 2022 4:00pm
Glibbs
I don't know if they are but they would generate blue smoke i believe. Thanks for your thought though. Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #632710 23rd May 2022 6:19pm
Dave lincs
Was it OK before you put fuel in? Whatever the RAC say have you checked your receipt
Post #632712 23rd May 2022 6:42pm
Caesium
Other than excess fuel, There’s only two things that an engine can burn to make smoke, thats oil or coolant.
Coolant makes white smoke normally and hard starting.
Oil can make blue or grey smoke. PCV being blocked would usually be accompanied by an oil leak from a seal or gasket due to over pressure in the crankcase. Christian.
Current Cars
2019 BMW X4
or
Post #632731 24th May 2022 5:33am
Glibbs
A complete and utter cockup on my part. . .
I topped up the engine oil and didn't put the cap back on. . .
No spillage from the engine, just the smoke plume from the exhaust.
Taking it out today to ensure it's OK.
Thanks for all of your help everyone. Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #632738 24th May 2022 6:59am
dingg1
This has to be a wind up, no one noticed that the oil cap wasn't on?
Mine runs like a bag of spanners without it and it would be apparent immediately imo
Post #632740 24th May 2022 7:20am
