![]() | Home > Maintenance & Mods (L322) > Inactive air suspension |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1218 ![]() ![]() ![]() |
No this is not normal, the hissing sound will be an air leak, from one of the following -
petebowling Member Since: 17 Jul 2018 Location: Thetford Posts: 20 ![]() ![]() ![]() |
Thanks for this will check this out, I’ve never heard the hissing before and it says on the Hawkeye cannot read a level so probably not getting to ride height to switch off pump due to a leak? |
Sounds like the rate of the leak is higher than the compressor capacity. I forgot to mention that the air reservoir cylinder is situated on the offside under the car between the wheels, worth checking the line from that to the front air distributor valve block as well. Good luck |
Cheers bud i will let you know how i get on. |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 158 ![]() ![]() |
I have a similar problem but no hissing!
This may not help, but......
Funny you say that, I’ve just purchased my L322 ( about 1 year ago ) when I got it I pulled the spare wheel out to check and clean the wheel well out as you do and i found 1/2 a bucket of water in there
Luckily in mine, the water was only in the wheel well, no water in any other compartments, tried every which way to replicate the leak / water entry, to no avail.
