Home > Technical (L322) > MY06 Handbrake |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
Is there an adjusting nut on the end of the single cable on the compensator? |
19th May 2022 11:49pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 573 |
Not that I know of, its not mentioned in the manual and not apparent in the diagram I posted.
20th May 2022 1:59am |
20th May 2022 6:00am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
There isn’t a way of tightening the handbrake cables, LRs solution is to replace the stretched cable with a new one.
20th May 2022 10:15am |
Thanks everyone
20th May 2022 11:33am |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
My handbrake was hopeless when I first got the vehicle and would struggle to hold the vehicle on a hill in neutral. When I changed the rear discs I used the adjusters to ease the shoes onto the drums and then backed off just a couple of clicks. That was a job in itself, lining up the star wheel with the access hole. Result was that the handbrake held the vehicle even in gear. I don't tend to use the handbrake very often, ensuring that it is good enough to pass MOT every time, for the last several years. Previous cars:
20th May 2022 4:37pm |
I've decided to buy new cables.....
23rd May 2022 3:24am |
