![]() | Home > Technical (L322) > MY06 Handbrake |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1296 ![]() ![]() ![]() |
Is there an adjusting nut on the end of the single cable on the compensator? |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 606 ![]() ![]() ![]() |
Not that I know of, its not mentioned in the manual and not apparent in the diagram I posted.
There isn’t a way of tightening the handbrake cables, LRs solution is to replace the stretched cable with a new one. |
Thanks everyone
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
My handbrake was hopeless when I first got the vehicle and would struggle to hold the vehicle on a hill in neutral. When I changed the rear discs I used the adjusters to ease the shoes onto the drums and then backed off just a couple of clicks. That was a job in itself, lining up the star wheel with the access hole. Result was that the handbrake held the vehicle even in gear. I don't tend to use the handbrake very often, ensuring that it is good enough to pass MOT every time, for the last several years. Previous cars:
I've decided to buy new cables.....
