![]() | Home > Maintenance & Mods (L322) > Fitting deployable sidesteps. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3149 ![]() ![]() ![]() |
My car has that switch too. I hadn't seen it before. I pressed it and everything electrical seemed to wake up.
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 294 ![]() ![]() ![]() |
The switch under the dash is for roof access. It allows you to deploy the steps permanently so you can access the roof (at leats that's what mine does). If you turn on the ignition and press the switch within 3 seconds it locks the side steps out and the switch lights up. To put the side steps back is the same procedure.
Ivan - that's the switch that you fit in the headlining up by the sunroof. Not the one with arrows on it under the dashboard.
OK must different on L405 to L322
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
If you have the fitting instructions ( a small booklet ) it is a guide for the function of the switch? When all working correctly turn the engine off, and ignition on only press the switch for 3 seconds the steps deploy for cleaning and do not retract until you move on.
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 676 ![]() ![]() ![]() |
Result guys, got the steps all working now. The correct loom and module all fitted but steps are a little slow, so I'm going to strip them down tomorrow and give them a good clean, they been in some dudes garage for 3 years collecting dust. Thanks for all your help guys.
Seriouslthinkingaboutit Member Since: 12 Mar 2022 Location: Essex Posts: 98 ![]() ![]() ![]() |
Well done Barmy |
Thanks Douglas, I'm well happy now. I'll shall put the other looms up on eBay, not sure anyone on here would want them, they don't come with the steps |
Can anyone recommend a good lubricant to use on my side steps? I've spent all day cleaning the crap out of all the hinges and used a whole can of WD-40. The passenger side is working perfect but still that little bit slow but the drivers side still needs a little help. The motor bracket moves but then goes back down again i presume it's because it thinks it's hit an obstacle. I believe it's the non motor brackets that are the cause and still a bit stiff. They are a lot better than they were but just need that little bit more better lubricant. They are not damaged or anything. |
WD-40 isn't a great long-term lubricant, it's more of a penetrating fluid. Ideally, you need to strip the moving parts, remove any corrosion and grease with something appropriate to the metal(s) such as white grease or Silicon grease, both will resist the incursion of moisture and 'road muck', white Lithium / Calcium grease is the better of the two for that purpose.
Thanks for that phoenix. Unfortunately i don't think I'll be able to strip them down, they have big pins in that i presume were inserted under high pressure like a wheel bearing so would never get them out. Though the 1 in the middle has hex bolt which i think you can undo and tap the bolt out to remove the pin (hopefully) so will give that a go In the morning. They were stored in a garage for 3 years so no doubt they collected more crap and the grease hardened. |
So this morning i decided to delve further as steps are still too slow in deploying. I decided to take these end plates off 2 on each bracket using T25 torx with hole in the middle (why they used those for I'll never know). They do round off rather easily so be careful. Got the plates off and the amount of corrosion and grit inside then was unreal. So gave them a damn good clean and cleaned all the crap from the pins and used plenty of WD-40 and left for an hour, slathered it in silicon grease and refitted the plates.
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Glad to read you got them fitted! And sorted the slow problematic movement.
