Home > Maintenance & Mods (L322) > Fitting deployable sidesteps.
Page 1 of 3 123>
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi guys I've just bagged a bargain of the century (well i think i have) a full set of deployable sidesteps which included everything needed to fit. Is there anybody on here that would care to fit them for me? Maybe someone around the Midlands or Bristol area or M5 corridor? I could possibly do them myself but i really don't have the time as they would be just sat in the shed for months on end. Obviously i would pay for someone to do it. Any recommendations would be rather welcoming.
Post #631504 13th May 2022 12:05pm
Barmybrummie
I've downloaded the instructions from topix and seems a rather straight forward job. I will be off next weekend so I'm going to tackle the job myself, is there anything i should worry about and also I've read somewhere else on here that it's just plug and play basically. I've got the gap iid tool to enable it in the ccf. And would i be wrong in thinking that some of the wiring looms are already fitted on a 2008 or have i misread something?
Post #631751 15th May 2022 5:36pm
cass
It's a few years since I fitted mine but I remember it being very straight forward - I'm sure someone on here has done a write up on it. The only problems I remember were needing some Taps to clean the threads on the holes that LR had thoughtfully left open to the atmosphere underneath the car and the cable that runs up to the overhead console is only just long enough, it needs to be very carefully routed from the ECU, there is no spare length.
It was plug and play on mine.
Post #631753 15th May 2022 5:43pm
theres a couple of how to's in our wiki that will help you.. ... - .- -.
Post #631779 15th May 2022 9:02pm
Barmybrummie
Yes cass somebody else mentioned that too, another tool set I'll need to buy, that's 1 thing I've not got. Been told that some can't be used using a drill because of the air tank. Thanks Stan I'll have me look.
Post #631780 15th May 2022 9:19pm
Barmybrummie
Well guys today i made a start on fitting the steps today, well if you can call it that. I had a lie in this morning for the first time in months, so today went off to Halfords to get me some kit which was sold out with what i needed. Went to another place and they too also sold out. So thought i would bite the bullet and try to see if i could get the bolts to screw in to the chassis instead of re-tapping them. A nice result though i say, bit fiddly but got the holes all ready to bolt the steps in just by screwing bolts in so that should be easy when it comes to fit them. Sprayed some WD-40 in the holes just to make sure.
Now this is where it gets interesting. When i purchased the steps, the guy said he was selling them cheap as the drivers side was automatic and the passenger side was manual. A bit strange i thought, so today i give the steps a good clean and oiled the moving parts. Then went through all the wiring looms to check everything was there and well, everything is there and another main wiring loom for the L405 complete with switch. On checking the main wiring loom it turns out it's the correct one for mine as it has the button that goes in the front roof panel. The dude who sold them never fitted them to his L322 and sat in his garage for 3 years, so i do believe he's got his wires crossed (no pun intended) and thought the L405 main loom was for the manual passenger side step. I really do think I've robbed the guy for what i paid for them.
So now i have a L405 main wiring loom and switch that i have no use for, so if anyone is interested i will put it up for sale in the for sale section. It also comes with the instruction booklet too.
L405 switch and loom.
Post #632145 18th May 2022 6:30pm
Seriouslthinkingaboutit
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Ah!!!
That’s the strange switch I saw in your pics. Explains it all.
Douglas 2007 4.2SC Buckingham Blue
https://www.fullfatrr.com/forum/topic63319.html
Post #632158 18th May 2022 7:31pm
dhallworth
I’ve just fitted these to mine.
I believe you can still get the looms and the ECU from Land Rover so if you’ve not got the right wiring it might be easy enough to sort.
Post #632176 18th May 2022 9:14pm
Barmybrummie
Thanks David, i do believe i have all the right wiring and looms, i checked them against the instructions. So I'll soon find out tomorrow when I'm going to fit all together. If so, I'm going to be a very happy man.
How easy did you find it to do? Did you fit the actual steps by yourself? I only ask as I'm on my own tomorrow and they are quite heavy so gonna have to try and fit them by myself.
Must admit Douglas, bit of a relief that I've got the right parts and no manual passenger side lol.
Post #632180 18th May 2022 9:48pm
dhallworth
There's a lot of dismantling on the interior, but I had no problems really.
My wiring seemed a bit strange as the loom that goes to the passengers side step was the short one and the drivers side the long one. I believe they were labelled wrong from the factory as the ECU sits in the drivers side so I swapped those around, other then that it was straight forward enough to follow the instructions. There's a handy DIY guide in the Wiki here that Greg wrote which is handy for reference too.
When I had my air receiver off I'd run a tap down the bolt holes on the car so they were nice and clean. With the air receiver in place that will be very awkward, probably impossible to do.
They are heavy to mount but not too bad as you start the bolts and then slot the steps onto them which makes life much easier.
Post #632184 18th May 2022 10:02pm
Barmybrummie
Thanks David. Yes i did see that in the wiki and is a very good write up. I did start a bit of the stripping down so tomorrow i can just crack on with it. Btw, was is it you that posted your working steps on YouTube with the same name?
Post #632187 18th May 2022 10:14pm
dhallworth
Guilty as charged Smile
The video's were hosted there and the link put into my thread on here. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #632189 18th May 2022 10:36pm
Barmybrummie
I need some serious help please guys. I fitted all the looms today, plugged them all in and............. Nothing! Checked, checked and double checked all the wiring, all in place except for a wire and plug that goes to the roof, these 2 here.
According to the instructions the loose wire should replace number 5 wire in the main plug
And the other wire should go into plug in the steps loom. Now i don't have a number 5 wire only 4 so I'm believing i may have the wrong loom for the 2008. This one is for 2010 on, is there a way around it for them to work or will i need to get a pre 2010 loom?
So now I've unplugged the steps loom and plugged back in the original ones into the ecu under passenger side, now my seats and steering wheel adjusters don't work. Tried with the iid tool but when i want to load up the ccf it keeps saying error then goes back to home screen. Any idea please guys?
Post #632256 19th May 2022 7:11pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Oof, that’s not good! Crying or Very sad
I’ve seen similar IIDTool issues that seemed to go away later. It felt like an ECU had an issue and when the car went fully to sleep it reset.
With that in mind maybe disconnect the battery, and try the “short the connectors” trick to reset everything?
Sorry, can’t offer much more help there… hope you suss it out Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #632257 19th May 2022 7:36pm
Barmybrummie
Thanks ffrr-lover I'll give it a go shortly. What year is your overfinch? The thing is if i can't get the damn things to work or can't get hold of the correct loom, then i will just put them up for sale again.
I'm hoping I've not frazzled the bcm.
Post #632258 19th May 2022 7:40pm
Page 1 of 3 123>
