Home > My Range Rover > My L322 Project
Page 7 of 8 <12345678>
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
A video of the stripdown and highlighting how bad the brake pipes were
 Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #631945 17th May 2022 10:22am
Caesium
A video of the new pipes in
 Christian.
Current Cars
2019 BMW X4
or
Post #631950 17th May 2022 10:31am
kevinp
Hey Christian. Excellent video mate.
I've bought some Cupro Nickel pipe and all the kit to do the flares and new hoses.
Would it be easier for me to do the right rear in 2 pieces and join it under the sill? I'm not planning on doing the sub frame bushes just now.
Cheers Kev.
Post #631969 17th May 2022 11:40am
Caesium
Hi Kev,
I'd absolutely do it in two pieces if I had the tools to make the pipes up.
I would probably make the joint by the fuel tank, that is the easiest location to site the joint and the place it becomes tricky to route. If your pipe is in a coil it might be much easier to do than my pipes were as they were already formed.
The fuel tank shield itself is a pain to get down, you may still need to loosen the NS subframe bolts and lower it a bit, it's easier than it sounds. Christian.
Current Cars
2019 BMW X4
or
Post #631970 17th May 2022 11:46am
kevinp
Thanks mate. I watched your video again and there looks a decent straight piece of pipe higher up to do the join. Thumbs Up
Post #631972 17th May 2022 11:58am
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
great work .....not much of a hard job just a bit fiddley wouldn't you say
Post #632064 18th May 2022 5:52am
Caesium
My original horns were sounding a bit off so I decided to change them.
Had to make up a fly lead to save the car wiring, I’ll edit that video together a bit later.
This is the sound of the old vs new. Not sure the video conveys the actual improvement which is really marked.
Here it is anyway
 Christian.
Current Cars
2019 BMW X4
or
Post #632571 22nd May 2022 6:42pm
francy
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
keep up the good work Thumbs Up
Post #632583 22nd May 2022 8:48pm
Caesium
It's not long before something else needed doing.
Saw some marks in the wheelarch liner and PRESTO!
The car has blown a CV boot.
 Christian.
Current Cars
2019 BMW X4
or
Post #636882 14th Jul 2022 2:38pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Just sufficient time for the skin to grow back on your knuckles Rolling with laughter Rolling with laughter BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #636884 14th Jul 2022 4:34pm
Superspoons
Nice work - enjoyed watching those videos Thumbs Up Gavin
https://www.youtube.com/@ChallengingClassics
Post #636901 15th Jul 2022 7:54am
Superspoons
Duplicate post Gavin
Post #636902 15th Jul 2022 7:54am
dhallworth
I do not envy you the job of replacing CV gators. One of my most hated jobs! 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #636909 15th Jul 2022 9:47am
dingg1
Knowing how much hassle getting that drive shaft through the hub can be, I'd have a closer look at the clamp and see if it could be possible just to clamp over the split, its not lost much grease at all and if the split is where it looks to be it just might be possible to get away with it.
Good luck Thumbs Up
Post #636911 15th Jul 2022 10:00am
Caesium
Can anyone recommend a decent 3 legged puller? There's loads of cheap crappy ones about but I want to get a decent one Christian.
Current Cars
2019 BMW X4
or
Post #636921 15th Jul 2022 11:46am
