Home > Maintenance & Mods (L322) > TD6 Brakes. At loose end |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Is the length of the servo pushrod compatible with your servo?
15th May 2022 1:11pm |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 |
The servo and Master cylinder were off a 2005 TD6 and came complete. So should be same as mine.
15th May 2022 2:16pm |
I don’t know about these cars but l seem to remember adjusting the push rod length on a discovery l had. Can’t remember why though.
15th May 2022 3:06pm |
Just been and checked (the servo I took off) doesn’t look like any adjustments.
15th May 2022 3:34pm |
No expert, but do you have to put the ABS unit in to bleed mode to get all the air out?
15th May 2022 3:55pm |
If that’s a thing, then could well be?
15th May 2022 4:01pm |
https://workshop-manuals.com/landrover/l32..._bleeding/ 2011 Range Rover Vogue SE 4.4 TDV8
15th May 2022 4:17pm |
70.25.02
15th May 2022 4:24pm |
Thank you so much buddy.
15th May 2022 4:32pm |
No worries….
15th May 2022 4:50pm |
Cheers anyway fella.
15th May 2022 5:16pm |
According to the above procedure outlined as the master cylinder is upstream of the brake modulator you need to have the system bled using T4 diagnostics.
15th May 2022 6:09pm |
Thanks all for the input.
15th May 2022 6:29pm |
I’d just use the hill decent as a first try. No need for low range or wet grass…. Just need a road on a hill… activate it then accelerate and then remove your foot… car should keep to a bit more than walking pace despite the hill. You will hear the ABS clicking. 2011 Range Rover Vogue SE 4.4 TDV8
15th May 2022 7:01pm |
