![]() | Home > Technical (L322) > Asthmatic L322 |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Recently I replaced my pulleys, alternator, water pump, and a few other bits.
Further to this i had a new noise today…
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Mine does that in reverse, as you power on and release, I have a step up into my garage and just squeezing throttle to get up there does it.
Cheers mjdronfield,
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 192 ![]() ![]() ![]() |
Are all the jubilee clips nice and tight on the turbo hose’s or have any split? 2016 4.4 diesel |
Funnily enough I was out this morning double checking everything. All hoses appear ok as best I can see without stripping everything down, and all jubilee clips tightened some more - none felt particularly loose.
Strangely enough when I was doing an oil change on mine I found a similar hose on the other side nr the air box. It's got a 180 deg bend at the top and is not connected to anything - does it go in the airbox and is it a breather hose? 2012 TDV8 Vogue (L322) |
The photo I took was the driver side and the hose appears to be a vacuum hose.
Further research has ID'd it as the front diff breather hose. 2012 TDV8 Vogue (L322) |
Good find |
As I found out yesterday as I was fitting mine back together googled the part number What did we do before Google ![]() |
