Home > Technical (L405) > Am I mad, or do I have a Reverse fault..? |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 597 |
My guess is you were in neutral not reverse on your first attempt.... Mike - MPx
15th May 2022 11:37am |
Swasher Member Since: 03 Nov 2021 Location: Suffolk Posts: 16 |
Ok, MPx, that would go along along with my 'Am I mad' theory, but it was in reverse and reversing, until I applied a little brake when the front wheels snagged...
15th May 2022 11:40am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1387 |
This has happened to me when off road, e.g. parked with a ridge, stone etc behind the car. I found it odd and surprising, and it is not something my earlier RRs did. I have got out of the car to see if there was an unseen larger obstruction, and there wasn't. Driving forwards a bit and then reversing had the car clearing it no problem. I took it to be a quirk of the traction control, perhaps linked to the drive characteristics of the 5.0SC, but it seems to have happened to you with the SDV8.
15th May 2022 12:01pm |
Thanks CS, it sounds like the exact same thing, even with your mahooosive v8.. it's reassuring to know that these anomalies are out there, and not necessarily worrying, just a 'quirk'. MY17 VSE FF Corris |
15th May 2022 1:33pm |
Martyg Member Since: 28 Nov 2021 Location: NI Posts: 7 |
Yeah same happened to me, bit of a lip going into my garage. Stopped at the lip one day and it wouldn't reverse over it, had to go forward a bit then reversed ok. |
15th May 2022 2:44pm |
