Home > Technical (L322) > L322 rear lights
Slow progress
L322 rear lights
Just about to order the original rear lamps, however when I look there are 2 variants. Mine is a 2003 should the lights be the ones with or without side marker? L322 TD6 2003
Epsom Green- the dogs car which has worked it’s way into being the family car 😮
Post #631660 14th May 2022 9:46pm
mjdronfield
No side marker. That’s for the American market.
Though a few on here have got them and got the side markers working, if I remember right.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #631661 14th May 2022 10:09pm
bgennette
Australia 2003 Range Rover HSE Td6 Java Black
It's also possible to fit later LED style lights, BUT there are 2 problems -
1) Plugs and low load mismatch. Wires can be soldered, ballast loads may be added.
2) A mounting lug is in a different position. Use water resistant 'liquid nails' to fit a small wooden block to screw into.
bye. 2003 TD6, EGR delete, vortex crankcase breather update, performance chip, UHF 2 way, Android head unit, crash camera on dash, always-on rear view camera to mirror screen, LED DRL`s, Electric trailer brake controller. FSR replaced. Pulling 3T caravan all about Australia
Post #634665 15th Jun 2022 7:17am
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
you are not wrong mr mjdronfield i have got the nsa style fronts wired up with led bulbs
. going to do back lights next week new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #634730 15th Jun 2022 8:33pm
