Home > Technical (L322) > Starter motor replacement L322 TDV8
Page 6 of 9 <123456789>
Shaun
England 2011 Range Rover Vogue 4.4 V8 Orkney Grey
Large red wire highlighted is the one to the starter, cut and spliced the new cable in. Fitted with shrink cap.
 2004 TD6 - Gone
2011 4.4 TDV8
Post #631439 12th May 2022 7:34pm
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
Shaun wrote:
Had a question from a member about the new cable I fitted, so a few photos attached.
Cable run carries on behind headlight, then down to subframe & Starter.
How is your starting now? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #631483 13th May 2022 9:44am
Shaun
No problems with starting over the last 3 years, just other stuff!! 2004 TD6 - Gone
2011 4.4 TDV8
Post #631648 14th May 2022 8:13pm
ffrr14
Thanks,
So you have not done the relay mod then? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #631665 15th May 2022 12:43am
ffrr14
This is my setup, I decided to make a dedicated circuit directly from battery with a robust 200amp relay but with an Auto Reset Circuit Breaker rated @40amp (same as starter relay fuse)
New : G350D
Post #631685 15th May 2022 9:42am
johnboyairey
So, I have done this modification, I guess as identical as Shaun’s car…and soldered in a parallel cable from the ‘x’ on this picture, through a hole in the fuse box, and run the cable down, through he wheelarch vents, and strapped it to the subframe, with some taped extra insulation on strapped cable contact points, and in to the starter motor area, and again soldered on to the trigger wire and taped all bare areas. So a parallel feed, which leaves all original wiring same, and will hopefully cure this annoying intermittent high resistance proble,. I will report back
Post #631707 15th May 2022 12:20pm
ffrr14
I think it is a design shortfall in the starter solenoid circuit which is further exposed by degrading wiring/contacts over time. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #631713 15th May 2022 12:50pm
ffrr14
The Crank profile looks different, i suspect it is due to inadequate solenoid contact
Before Mod
After Mod
New : G350D
Post #631714 15th May 2022 12:51pm
ffrr14
Update:
Car continues to crank strongly, even with low SOC.
This perticular mod is highly recomended for the 4.4TDV8 in my opinion and likely prevent starter issues. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #632398 20th May 2022 11:32pm
mezo
United Kingdom 2012 Range Rover Vogue SE TDV8 Java Black
Having lack of start with lowish (~12.3v with accessories on) battery - starter and battery changed and was pointed to this thread.
I measured the resistance of the red starter wire and on my car it was 0.2 ohms - the 3 meters of 50A thinwall automotive wire i ran in parralel did't register any ohms on my fairly decent brymen meter.
Spliced the wire into the existing red wire in the fuse box, ran the wire behind the headlamp, then followed the subframe onto the engine near the steering rack and then followed the OEM harness towards the starter.
Soldered splice - this isn't a great way of doing it and would suggest crimps.
Post #632819 24th May 2022 10:30pm
Phoenix
Measuring resistance on a passive circuit won't give any meaningful diagnostic clues unless the wiring is degraded significantly, volt drop measurement with a reliable meter, leads and good connections is the only way to properly diagnose these sort of issues. I use Fluke meters and dataloggers costing a reassuring amount and are calibrated every six months, i'm not sure I'd put too much faith in unverified readings from 'prosumer' level kit, even if it produces pretty graphs on a phone.
Despite technology, electrical faults are still the same as 100 years ago, connection, corrosion & consumption
Post #632824 24th May 2022 10:49pm
mezo
The pretty graphs as you put it are from a cheap datalogging device and is handy to see what’s going on and keeps a history in order to try and determine any patterns or eliminate areas - it’s not a precision instrument, but it’s not bad.
I have current clamps, current shunts, digital scopes and a decent calibrated meter that is more accurate than the fluke equivalent - but I cant drag all that crap out the workshop trying to track down an intermittent fault that may not happen for a week or more
This £25 gadget can show you the exact voltages during the 1 second crank, I have an oscilloscope - but that’s an expensive nerd luxury that few can justify.
Post #632829 24th May 2022 11:34pm
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Great job mezo, you’re definitely adding value to the forum with your approach! I really do hope your new cable gives better starting consistency and allows you to better fault find any potential charging issues on the other thread. Also, if you still get the odd no-start then it will be easy to just add a new relay to provide a 12V feed directly from battery +ve to solenoid. I’m looking forward to hearing how this fix works out for you 👍 Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green. Currently SORN whilst undergoing some serious restoration!
Post #632831 25th May 2022 6:32am
johnboyairey
I too have added the parallel wire, soldered in from fuse box to trigger wire, and can report that it’s works every time… I’m only a few weeks into this, and want to confirm it’s a long term fix, a bit later on. It’s certainly an easy solution.
Post #632832 25th May 2022 7:20am
Phoenix
mezo wrote:
... from a cheap datalogging device and is handy to see what’s going on and keeps a history in order to try and determine any patterns or eliminate areas - it’s not a precision instrument, but it’s not bad.
I don't agree, unless the voltage being measured is shown with some sort of verifiable, repeatable accuracy, it could well be sending you off on a wild goose chase, there is also the issue of confirmation bias - 'it's always that cause, so it must be that cause in this case' type of thinking, also, I'd take issue with an indicated 9.85VDC during cranking being 'OK', it most certainly isn't, anything below 10.5VDC during cranking is an issue, on any 12V vehicle.
It would be better in my view to measure volt drop end-to-end during cranking to determine if the issue is the circuit or the supply to it.
Post #632833 25th May 2022 7:26am
