Home > Maintenance & Mods (L322) > fitted second battery in the back
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
fitted battery in the back today long day but all looking good and no cutting of any plastic if you use the right terminals and cables. tested with a meter and working well . just need to sort out a small 12 volt battery pack now just incase the main battery goes down so i can fire up the 100 amp relay so that it will bring in the second one in the boot to start the beast .
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #630720 5th May 2022 5:38pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
Looks good, nice job Thumbs Up
Why a 12v batery pack just to energise the relay/solenoid though? You could simply have a suitable fused switch feeding from the 'new' battery to energise the relay and link it with your flat one. Or just fit a simple T-Max controller that will also re-charge your aux once your main battery is up to suitable voltage? FFRR SDV8 Autobiography
Post #630763 6th May 2022 8:31am
GraemeS
Which model Varta did you fit?
Edit - I've spotted the H3.
Post #630764 6th May 2022 9:01am
TDV8 Paul
Probably a silly question but I’ll ask anyway, what’s the purpose of fitting a second battery? Does it make a lot of difference in the day to day running? Just intrigued 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #630798 6th May 2022 3:46pm
Dolphinboy
It helps avoid the dreaded 'low battery - please start engine' warning. and it means you can listen to the radio with the engine off for more than 5 mins Mr. Green
Post #630805 6th May 2022 4:59pm
oggy
hi james i think i understand what you are explaining . at the moment the second battery is switched on when ing key goes to first position using the green wire in the trailer socket . and it is charging all okay from the alt . so if i take a power live from the second battery in to a switch and then in to the 100 amp relay i can switch it by hand to energise the relay . can i piggy back into the same relay wires 85/86 ing live / and earth new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #630813 6th May 2022 6:52pm
GraemeS
My aux battery is a deep cycle AGM used to run a fridge that runs even when the engine isn't running, possibly overnight if camping.
Post #630836 6th May 2022 9:29pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I would suggest a Voltage sensing relay to protect the main battery. You can get them that have an override switch and also work both ways ie if you charge the Aux or connect a solar panel once the Aux battery is full the relay switches and the main battery will charge. I would also recommend lifting the loom out of the battery area and securing it above the fusebox, there is enough length. https://www.australiandirect.com.au/Batter...U8QAvD_BwE 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #630854 7th May 2022 1:47am
oggy
thanks wayneg for the advice i am waiting for a meter of elec flex tubing to come to wrap the loom to stop it from rubbing thanks oggy new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #630901 7th May 2022 1:43pm
